Author Topic: Boiler issue for a friend  (Read 2289 times)
Offline golf-sib
  • Турботазик
« on: 09 February 2013, 18:01 »
Hi, I know there's a few helpful plumbers on here, my friends got a Worcester 24i RSF Combi and they wanted an opinion before they call a plumber out. Basically the boiler comes on and off as it pleases for the heating and they seem to have a similar issue with hot water, they usually hear the boiler fire up as they turn the hot water off.
Thanks in advance!
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline dragongreengolfgti
  • my golf gti mk3
Re: Boiler issue for a friend
« Reply #1 on: 09 February 2013, 18:09 »
I'm not a plumber but it sounds like they have a thermostat somewhere for the heating which would cause it to cut in and out when the temperature hits the correct temp in the room. As for hot water our system cuts the heating off when using hot water and when filling up the expansion tank. We have an air to water system which works different to a normal system. Basically when using hot water it overrides the heating if that makes sense.
This may not be what's happening to your mates i'm sure someone will have another answer soon  :smiley:
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #2 on: 09 February 2013, 18:10 »
Have they tried "Googling" it.
Offline dixie180
« Reply #3 on: 09 February 2013, 18:21 »
Ask your friend if the pressure needle is on the red mark on the pressure gauge.Alternatively they can try here.http://www.diynot.com/forums/viewtopic.php?t=151549
Offline T_J_G
« Reply #4 on: 09 February 2013, 19:08 »
Speak to JustAlex on here, he's in Kent too.
Offline golf-sib
  • Турботазик
« Reply #5 on: 09 February 2013, 19:53 »
Yes I've tried google, throws to many results up, from relay, to pressure switch, to thermostat, to a brick thrown at a boiler. Needles not on red but at 1.5 bar, the hot water problem was described as:
When u turn hot tap on only sometimes goes warm then back to cold, when u turn tap off boiler kicks in but when you turn tap back on the boiler goes off
1.8T AGU..
R135
  24
Offline Toby
  • Car - less
« Reply #6 on: 09 February 2013, 20:06 »
It's not frozen outside? Or the condenser pipe blocked ?
Just a thought   :rolleyes:
Currently down under
Offline golf-sib
  • Турботазик
« Reply #7 on: 09 February 2013, 20:40 »
I've asked him to check that, but is like err whats it look like, I have explained its the plastic pipe that goes into any waste pipe as the water is acidic. I've told him to throw a brick at it, but his in sheerness and I'm transportless atm and in northwest kent.
1.8T AGU..
R135
  24
Offline Toby
  • Car - less
« Reply #8 on: 09 February 2013, 20:42 »
Brick isn't the answer lol
Cheapo mate.  Lol
Offline golf-sib
  • Турботазик
« Reply #9 on: 09 February 2013, 20:53 »
Dam right I'm a cheapo, golfs sorn, motorbike got stolen and going through insurance and the recovery vehicle the ka is with someone else  :grin: :grin: :grin:
1.8T AGU..
R135
  24
