Author Topic: iv had enough of it  (Read 4731 times)
Offline Itteh
  • Built Not Bought
Re: iv had enough of it
« Reply #20 on: 10 February 2013, 12:10 »
At mo it looks like urs andd the image was taken early last year the images before i sorned it luk even beta lool and crap ma new backbox was loudn had a very different deep tone nt like boy racers that the hole area can hear when ther only on 2500 revs ! !
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #21 on: 10 February 2013, 12:15 »
I know this might not look like your sensor but have a read of the symptoms and tell me if you having similar problems.http://www.aa1car.com/library/air_temp_sensors.htm
Offline MereKat
« Reply #22 on: 10 February 2013, 12:28 »
What is the fault code from VCDS? And if a bracket on the backbox is a problem then a quick bending session may sort it. If it's snapped off but everything else looks fine I'm sure there'll be someone local that could weld it back together with ease :)
Im at this point with mine, but will persevere with it as I know it'll be a good car when I'm eventually finished with it :D
As said, mk3's are relatively simple cars and most problems are generally simple fixes
Offline Itteh
  • Built Not Bought
« Reply #23 on: 10 February 2013, 13:52 »
in the image you can see i have unplugged the maf sensor wire, it has been runnin okayish since, but i need to know the problem with the car, here is the image one of u helpful guys asked for
Offline dixie180
« Reply #24 on: 10 February 2013, 14:02 »
Right,in the pic i don't see any wires coming out of the plug that sits on top of that little round cylinder to the left of the MAF sensor.Plus is that white thing that looks like its plugged into the shoulder of the filter connected to anything ?
Offline Itteh
  • Built Not Bought
« Reply #25 on: 10 February 2013, 14:16 »
the one on the left is connected as theres a green wire coming out of it... look  closely n im surwe ul b able to see it and the white thing is another little filter, its not connected to anything tho........ its always been like that....
Offline dixie180
« Reply #26 on: 10 February 2013, 14:36 »
Well where that little white filter is should be where your air intake temperature sensor is plugged in.That sends a message to the ECU to tell it the air temperature so it can determine the air/fuel mixture.Have you had a problem with excess fuel use,misfire on cold days,stuttering on acceleration in cold weather ?
Offline Itteh
  • Built Not Bought
« Reply #27 on: 10 February 2013, 16:02 »
Iv had a problem with excess fuel and it recentley started messn about with shidderin when its cold hw much is this sensor ?
Offline dixie180
« Reply #28 on: 10 February 2013, 17:17 »
The sensor is about £25 from GSF.You should have a cable down to the left of the small cylinder that orignally had the sensor attached to it.Mine are taped together with the MAF sensor cable.
Offline danmusic24
« Reply #29 on: 10 February 2013, 17:46 »
you could end up chucking loads of money at  it replacing parts,seems strange that it was ok then you have left it off road for 4months and all of a sudden you have a running issues! might be worth before you spend a arm and leg checking all connections for damp,cleaning all sensor connections.bet it turns out to be something that you have over looked!...have you not got a golf guru up your neck of the woods that could help? hope you get to the bottom of it fella :smiley:
« Last Edit: 10 February 2013, 18:32 by danmusic24 »
