Author Topic: iv had enough of it  (Read 4730 times)
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
Re: iv had enough of it
« Reply #30 on: 11 February 2013, 22:18 »
Hi ltteh,just a quick thought.If the air intake temperature sensor cable has been cut i'm afraid you won't be able to delete the fault.The ECU needs to get a signal from all sensors but if the cable has been cut it will continue to show a fault.
On another note you said the car had been stood for 4 months.That would take us back to October when the weather was milder and slightly drier than now.Now the colder weather is here you can get the crap cold start running issues.
« Last Edit: 11 February 2013, 22:23 by dixie180 »
Offline Itteh
  • Built Not Bought
« Reply #31 on: 12 February 2013, 18:12 »
God, well iv given it in to garage, and asked em to check it from head to toe for the intake problem. i explained as much as i could regarding the fault, and told them about this sensor that is apparently missing, as someone mentioned, also would trying the standard airbox be any better ? ? its been parked since mid sept, could it be fuel relay ? or anything even that sort ? the air temp sens cable, hasnt ever been on the car, i mean i put the induction kit on it, april 2011 or sometime then, my mate frm work was a mechanic he put it in for me, since then it was runnin spot on, its just nw after the park up it got effed up, feel like gettin a total diff setup on it, like a 16v buh i dnt throw money on it, as 16v will set me back 400 odd and then the labour another 3 or 400, ......
