Author Topic: temp gauge not working help  (Read 2230 times)
Offline wolfie1981
« on: 08 February 2013, 20:13 »
hi guys ent been around for awhile just bought a 2000 agu 1.8t but the temp gauge only moves up a tiny bit like one little line.
the temp sensor looks like its been replaced if im looking at the right thing?? on the right side of the engine on a water pipe green thing lol.
 I have fault code 16500 engine coolant temp / circuit-range/performance problem
any help would be great :laugh:
Offline Nino
Re: temp gauge not working help
« Reply #1 on: 08 February 2013, 20:17 »
Yep thats the sensor, have you looked to see if the Thermo needs replacing? Mine did this, replaced the thermo = problem fixed. :)
Current - MK6 GTi Edition 35
Offline wolfie1981
« Reply #2 on: 08 February 2013, 20:37 »
the water pipes feel quite cool even after a hour of driving heater gets warm fans on the rad kick in !!!
could the stat be stuck open ???
will it cause me any probs driving it like this only just bought the car lol
funds are low is  the stat behind the cam belt??? not sure
« Last Edit: 08 February 2013, 20:42 by wolfie1981 »
Offline Nino
« Reply #3 on: 08 February 2013, 20:59 »
its on the front of the block, near the middle, will cost you about £13-16 for a new part and you can change it yourself with the correct tools, Id do it if I were you otherwise you have no idea if your car is over heating or not.
Offline stfc_gti
« Reply #4 on: 08 February 2013, 21:01 »
defo the stat, had the same issue, had my temp sender replaced too.
it wont cause any issues but you as already said, you wont konw if your car is over heating.
2002 1.8T GTI AUM, Standard (not for much longer)
Offline wolfie1981
« Reply #5 on: 08 February 2013, 21:30 »
thanks guys will get one from tps tomorrow
Offline Dalo Harkin
« Reply #6 on: 09 February 2013, 09:45 »
If it goes up one bar it should keep going in theory, check the wiring first, I have seen a few of these with temperamental wiring, I have had to plug / unplug some 4 or 5 times before they work
Offline wolfie1981
« Reply #7 on: 09 February 2013, 19:46 »
done what you said mate now works a treat :grin:
Offline Dalo Harkin
« Reply #8 on: 09 February 2013, 19:56 »
Glad it's sorted  :wink:
Offline wolfie1981
« Reply #9 on: 10 February 2013, 18:20 »
UPDATE!! want out today for a drive for around 30mins gauge still at one bar. if left on the spot running after the run slowly comes up to 90.
do you think that the stat has had it???  :cry:
