Author Topic: temp gauge not working help  (Read 2228 times)
Offline opel
Re: temp gauge not working help
« Reply #10 on: 10 February 2013, 18:37 »
Thermostat mate
Offline wolfie1981
« Reply #11 on: 10 February 2013, 18:47 »
thanks mate will get one tomorrow
Offline thatwillis
« Reply #12 on: 10 February 2013, 21:15 »
I've got exactly the same issue in mine at momment. But I replaced both the temp sender and thermostat less than a year ago. Anything else worth checking?
Offline rio_gti
« Reply #13 on: 10 February 2013, 21:17 »
pump  :undecided:
Offline wolfie1981
« Reply #14 on: 10 February 2013, 21:25 »
see when you did changed them did it again or stay the same???
Offline wolfie1981
« Reply #15 on: 10 February 2013, 21:27 »
pump  :undecided:
surely if the pump as F**ed car would over heat??
Offline opel
« Reply #16 on: 10 February 2013, 22:40 »
Yer open the expansion tank cap and see if the water being pumped back in to the tank with a few revs on and it may be a faulty thermostat even after a year
Offline wolfie1981
« Reply #17 on: 10 February 2013, 22:58 »
well my water pumps back in the header tank after a few revs I shell go get a stat tomorrow and if the weather hold off might have ago at changing it will I need gasket sealer as well??
Offline opel
« Reply #18 on: 10 February 2013, 23:06 »
It a rubber seal u may get it with the stat.. But if you get it from vow I think you have to buy on might be wrong on that tho
Offline wolfie1981
Re: temp gauge not working help update!!
« Reply #19 on: 21 February 2013, 20:18 »
replaced stat today what a pig got there in the end. temp comes up to 90 now after a short run  :grin:
the bottom hose seems to stay cold for a very long time and the top hose red hot is this normal
after a  good while the bottom hose gets just as hot is this because the stat has opened ?? hope so
« Last Edit: 21 February 2013, 20:23 by wolfie1981 »
