Author Topic: What a game...  (Read 1887 times)
Offline D Squared
What a game...
« on: 08 February 2013, 18:51 »
Anyway in process of fitting my coil overs, everything is seized,had to drill top of shocker to get nut off...blooming old cars.. Anyway, whilst stripped out noticed N/S outer drive shaft gator is leaking, so thought I better renew it....What size is the centre drive shaft nut? And what torque is it? And does the outer joint come off via a circling or something? Or does the whole shaft have to come off, remove inner joint to enable fitment of the new outer gator?
Cheers DD
MK3-MK5- Now MK7 GTi
Offline madmanmart
Re: What a game...
« Reply #1 on: 08 February 2013, 23:38 »
Driveshaft nut is a 30mm bi-hex.
Undo the Driveshaft then the bottom ball joint, you can then remove the driveshaft to change the gaiter.
As you said I removed the inner CV then the outer gaiter.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline mattrobinson1982
Re: What a game...
« Reply #2 on: 09 February 2013, 22:42 »
has to be multipoint socket to remove the main driveshaft nut; normal hex nut won't fit. Undo it while the car is on the deck - it'll be tight  :cool:
Offline D Squared
Re: What a game...
« Reply #3 on: 13 February 2013, 21:56 »
Does the outer joint not come off? So therefore the whole shaft has to come off, take inner joint off then slide down gator?
Offline CJA321
Re: What a game...
« Reply #4 on: 13 February 2013, 22:05 »
Bottom ball joint out, driveshaft nut off. Chap driveshaft through hub, cut old clips off cv boot, cut cv boot off, chap off outer cv join, replace boot and fill with grease and new clios. Refit all back up.
But if everything is seized i have money on your cv joint being stuck in the hub
Offline D Squared
Re: What a game...
« Reply #5 on: 14 February 2013, 12:48 »
oh ok, so i don't need to take off whole shaft, then inner cv...the outer cv must then release via a circlip or spring type clip or something then?
can you confirm torque setting for nut, and what size it is?
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: What a game...
« Reply #6 on: 14 February 2013, 12:58 »
Whatever u do, don't wack the driveshaft out if the hub with a metal hammer
Use a nylon or similar
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: What a game...
« Reply #7 on: 14 February 2013, 13:04 »
Hub puller?
