Author Topic: fitted my eBay chip today!  (Read 8982 times)
Offline tweed
Re: fitted my eBay chip today!
« Reply #40 on: 10 February 2013, 19:51 »
Some people need to learn for about eletronics and plugs.
Air bag is fine to disconnect while battery is connected.
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #41 on: 10 February 2013, 20:25 »
surely you disconnect the battery for the airbag to release the charge so it doesn't go off in your face?
Offline Screech16v
  • MK3 20vt AGU
« Reply #42 on: 10 February 2013, 20:35 »
The air bag needs a signal from the ignitor and that will need a signal from a sensor and this will need power from the ignition so I very much doubt the airbag could ever accidently go off  ,but still knowing this I allways disconnect the battery  :grin:
Offline decksla
« Reply #43 on: 11 February 2013, 12:09 »
i just did this to my mk3 vr6.  cheapest mod ever!
i got a handy elec guy to solder in a socket as my original chip was soldered to the board.
i also had to get vagcommed to get the factory immobiliser to adapt to the new chip
a definite improvement in the lower revs range (2-3500).  ive done a pod filter and a CAI, extractors, and a 2.5in exhaust.  but this chip was the biggest "seat of your pants" feeling mod!
no petrols figures yet, but im certain it will be less.  the tune seems to be a little leaner, as the car doesnt pop and fart as much hopping off the gas.
that said, im driving it harder, so fuel consumption could be worse!  :)
highly recommended
Offline Len
« Reply #44 on: 11 February 2013, 13:01 »
It is recommended to disconnect. If you want to risk serious injury by not doing so then go ahead!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #45 on: 11 February 2013, 13:05 »
Actually if you read a Haynes manual it tells you to disconnect the battery if you are doing any electrical related work!
Bit excessive for plugs/leads etc and changing fuses/relays.
www.sas.org.uk
www.the-ace.org.uk
