Author Topic: fitted my eBay chip today!  (Read 9023 times)
Offline Screech16v
  • MK3 20vt AGU
Re: fitted my eBay chip today!
« Reply #30 on: 10 February 2013, 15:04 »
are all 16vs pop in? dont wanna buy one if i have to faff about soldering stuff?
Yes 16v are all push fit
Nice sig btw  :cool:
Offline vr6D4v3
« Reply #31 on: 10 February 2013, 15:30 »
Are these chips really worth it? I have a vr6, what benefits would I get once fitted?
To anyone that has done this already, how about a to do guide with some pics, they always speak a thousand words.
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #32 on: 10 February 2013, 16:47 »
not sure about a vr but is imagine it would give you similar benefits to the 16v chip.. drivability is better and smoother, better response, more power and sometimes better mpg although I'm yet to drive sensibly enough to see it yet :)
I'd imagine there would be a how to if you search the net..
in a nutshell do this though (piece of pisss to install)
1. disconnect battery
2. remove black plastic trim under right hand side of bonnet between engine and windscreen, a couple of x-head plastic screws
3. ecu is to the left of cabin filter
4. remove 2 10mm nuts
5. pull out ecu
6. pull back plastic cover exposing the loom plug
7. pull off air hose if you have one
8. pull ecu plug out
9. remove 4 torx screws and 2 x-head screws and pull circuit board out
10. unclip chrome cover
11. pull out old chip
12. push in new chip
13. reverse for re-install
simples :)
comes with instructions too
Offline Khare
  • The bear that khares
« Reply #33 on: 10 February 2013, 17:04 »
Can I point out battery needs to be disconnected from BOTH TERMINALS! and leave half hour disconnected before unplugging the ECU.
Otherwise this happens
Thankfully I managed to repair it properly and it's been fine since.
Offline mrsaunders
« Reply #34 on: 10 February 2013, 17:14 »
Nice sig btw  :cool:
Cheers done abit of work over the weekend, and got a nice 16v badge of a kind member on here  :wink:
Offline mrsaunders
« Reply #35 on: 10 February 2013, 17:16 »
you've worried me a little   :shocked:
« Reply #36 on: 10 February 2013, 17:51 »
you'll be fine mate as long as you follow the instructions. I disconnected both and pulled the ecu out right away and had no problems whatsoever.
Offline danmusic24
« Reply #37 on: 10 February 2013, 17:59 »
so how and what do these chips do?  cant understand how its gives you more power? surley you need a balanced fuel and AIR mixture? :undecided:
Offline Len
« Reply #38 on: 10 February 2013, 18:00 »
Khare should have known better!
It has been said many, many times on here that if you are doing any electrical work then disconnect for at least 15 minutes.
Disconnect completely! Both terminals and make sure those terminals an not touching any metal of the car.
This applies to things like air-bag removal.
This will also reset the ecu as well.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #39 on: 10 February 2013, 18:02 »
The standard fuel/air mix is set lean and so is the ignition.
So the chip changes both for the better.
Not all chips are the same and some like mine dont give the same power.
www.sas.org.uk
www.the-ace.org.uk
