Author Topic: Can't believe in thinking this but  (Read 3464 times)
Offline Leroy
  • Golf GTI Anniversary 16v
Re: Can't believe in thinking this but
« Reply #10 on: 08 February 2013, 08:39 »
At least lower it a bit, god i can't stand the look of my car at standard ride height, i think it looks awful. can't wait to get my coileys on next week.
Snap out of it minty!!!
Offline Metallix
« Reply #11 on: 08 February 2013, 10:26 »
Best mix of fast road handling, comfort, value, slightly lower =
Boge turbo shocks + Eibach spring kit
^ handles much better than a coilover kit for the same money.
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #12 on: 08 February 2013, 11:37 »
Cheap coils are still pretty harsh at close to normal ride hight from my experience, the AP's I have on my white golf however ride as soft as silk with a little drop.
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #13 on: 08 February 2013, 12:16 »
how much can you get this for? same as a price of joms?
Offline Metallix
« Reply #14 on: 08 February 2013, 12:31 »
Spring kit is ~£140
Shocks are just a decent quality standard item.  They were available from GSF for something like £35 each, but you may need to contact a branch rather than use their web.
If your standard shocks are ok then they should work fine with the spring kit, it's jsut very well matched to these dampers.
Offline Len
« Reply #15 on: 08 February 2013, 13:02 »
I guess it depends how old and worn your shocks are.
If you have a fairly new set then handling will be better.
Sorry but ya gotta lower it! 25/30mm at least as it looks like a 4x4 if you dont!
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #16 on: 08 February 2013, 13:18 »
Cut a coil  :lipsrsealed:
« Reply #17 on: 08 February 2013, 14:21 »
+1 on this. standard height looks terrible.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #18 on: 08 February 2013, 15:24 »
Standard ride height   :sick:
Offline boneybradley
  • Back in a Mk3...
« Reply #19 on: 08 February 2013, 15:32 »
I have had (over the years)
boggo std set up
non branded springs - o.e shocks -40mm
eibach springs - sachs/boge shocks -40mm (although it was more 25mm)
cheapo coilovers
fk top adjsutables and fk springs -40mm (again 25mm)
and the only one that gave any decent comfort was the o.e set up, even the boge/eibach was what i call "you can feel it" harder.
I have read about (semi custom) avo coilovers that have proper spring rates giving really good ride quality but they are £500!! they are said to be closest to o.e comfort when set correctly (not silly low)
