Author Topic: Brake booster mod  (Read 5180 times)
Offline brianpologti
Brake booster mod
« on: 05 February 2013, 17:42 »
Has anyone else done this
http://myfastgti.com/volkswagen/threads/15839-MKIV-GTI-GLI-1.8T-PCV-Delete-Catch-Can-Install-amp-Brake-Booster-Mod
I ve done the usual catch can and delete n249, but I not sure on this won't it effect the sevo operation,
Offline Dalo Harkin
Re: Brake booster mod
« Reply #1 on: 05 February 2013, 19:39 »
Not done this one but I have had to 're route mine, I'm using the S3/LCR inlet so the breather is on the opposite side, you can pull the 90 degree piece lot of the servo and then connect it to any vac source really. It's just a case of routing the plastic lines
jockgti
« Reply #2 on: 05 February 2013, 20:28 »
i did the pcv breather mod when i fitted catch can and have only 1 line going to brake booster
Offline rockmonkey69
« Reply #3 on: 05 February 2013, 20:48 »
I did mine, got rid of some leaking hoses and fitted a catch can in the process, it has helped to catch alot of the waste that would otherwise be plumbed back into the engine.
Sorry the engine bay is a mess, I am still sorting out the wiring and the engine bay hasn't been cleaned in months!
Offline GTi_James
« Reply #4 on: 05 February 2013, 23:37 »
dont be so modest lol
love this engine bay but havent had a chance to do mine  :sad:
Offline Scott D
« Reply #5 on: 06 February 2013, 00:01 »
I did this when installing a catch can, didn't notice any difference afterwards with servo assist.
Is an awesome engine bay that
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
« Reply #6 on: 07 February 2013, 15:42 »
It's very nice of you lot to think so, the engine bay has been neglected and the majority of the plumbing were only ever intended to be a temporary solution. All of which will soon be changed for a final solution to the standard pcv plumbing.
Offline MattyV6
  • Mk4 .:R32 - The Black Destroyer
« Reply #7 on: 07 February 2013, 18:38 »
Thats a nice clean looking bay  :smiley:
Wish mine looked like that!!!
Not in any way standard :) Dyno Dynamics RR - 280bhp
