Author Topic: Cold start problem  (Read 2121 times)
Offline dom
  • Back in a Mk4
Re: Cold start problem
« Reply #10 on: 06 February 2013, 20:05 »
Temp sensor could be somthing to think about Dom, when I first got mine it had a £6 temp sensor in and had the exact same issue, if you boot it through the gears while its faulting does it like hold back and not rev past 4.5k ? Mine did, put a genuine temp sensor in it hasn't faulted once!, it was reading so thing like -36 in measured values the  Gsf  "bosh" sensor
Doesn't hold back at all when warm, going to try some new plugs in it at the weekend and see if that makes a difference :wink:
Offline Dalo Harkin
« Reply #11 on: 07 February 2013, 06:53 »
I know you have a decat, but those symptoms sound like lambda to me, especially from cold
Hmmm, well the 2nd lambda hasn't been coded out since the decat. Although I assumed that it would throw up the CEL light, or at least a fault code?
Not always no, the front lambda (nearest the engine) and as your issue is ONLY from cold I would look at that  :wink:
Offline dom
  • Back in a Mk4
« Reply #12 on: 07 February 2013, 22:17 »
Yeah, reckon you might be right.
Are the two sensors interchangeable? I.e could I just swap the pre/post cat ones over to see if it improves?
Offline dom
  • Back in a Mk4
« Reply #13 on: 07 February 2013, 22:33 »
Scrap that, one is wideband the other is narrow so it won't work. New sensors are expensive :shocked:
Offline Dalo Harkin
« Reply #14 on: 08 February 2013, 11:41 »
They are expensive £70 odd from memory, have a look on eBay first mate for spares that's what I did
Offline Jona gti
« Reply #15 on: 13 March 2013, 07:32 »
Hi Dom. I'm having the same symptoms as you. Did you have any luck in solving it?
Offline dom
  • Back in a Mk4
« Reply #16 on: 13 March 2013, 17:34 »
Nope, logged lambda via vagcom and the readings were normal. Next step is a fuel filter change with a service next weekend. I also intend to do away with the PCV/EVAP/SAI system over Easter to eliminate a load of hoses that could potentially be leaking :smiley:
Offline Jona gti
« Reply #17 on: 13 March 2013, 22:21 »
Ok tidy. Keep us updated if you manage to solve it. Thanks for the reply  :smiley:
