Author Topic: Squeaky boost leak?  (Read 1196 times)
Offline Gabriel2202
Squeaky boost leak?
« on: 04 February 2013, 14:16 »
Anyone else had a squeaky boost leak?!
I think it's a boost leak as when the turbo comes on a continuous squeak comes from somewhere infront of the drivers side behind the dash... Literally sounds like a mouse! Though I recently checked all my pipework and tightened my clips and they were fine??
Anyone got any other suggestions on what I should look at?
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline stfc_gti
Re: Squeaky boost leak?
« Reply #1 on: 04 February 2013, 15:42 »
check the pipe that runs off your intercooler, i think its the pancake pipe? I believe you can get access to it via the front driver side wheel arch.
Someone will correct me if im wrong.
2002 1.8T GTI AUM, Standard (not for much longer)
Offline Gabriel2202
« Reply #2 on: 04 February 2013, 16:26 »
Yeah that's right, I have checked all those, I was driving earlier with the window down and it seems to be from in the cabin, now i'm thinking maybe the hose to my boost gauge is loose after i took out my dash
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline Dalo Harkin
« Reply #3 on: 04 February 2013, 17:08 »
DV in the right way??
Offline Gabriel2202
« Reply #4 on: 04 February 2013, 18:01 »
yeah DV is on the right way around, it was running fine (apart from the electrics) its only been since the snow, I didn't use it at all for 2 weeks during the snow, but since driving it again its been doing it... i'm sure that's just coincidence!
I'll get it scanned so i know for sure
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline Rico_GTi
  • Golf GTI 1.8T AGU
« Reply #5 on: 04 February 2013, 21:29 »
Do you have a boost guage fitted? The vac line and/or the guage can squeek if there's no "no buzz" T piece fitted.
To be fair though it's not the sort of problem that develops, would just do it straight away after fitment. Just a thought :undecided:
AGU........
Offline tshirt2k
  • Been there...Done that...
« Reply #6 on: 04 February 2013, 23:36 »
Sounds like you could have a leak on the boost gauge line. The pipes you usually get with the gauges are clear and can go stiff in The cold. Maybe it leaks under pressure through a tiny hole.
Mk3 ABF 16VT Megasquirt V3
Offline Gabriel2202
« Reply #7 on: 06 February 2013, 17:23 »
Found the bugger! Turns out all my seals are fine, vagcom showed no leaks which puzzled me even more. then i noticed my drive shaft has a tiny ring around it, turns out the nut holding the pancake pipe up has done a runner and the pancake pipe catches my drive shaft which makes a squeal at a certain rpm, which just happens to be when the turbo kicks in!  :smiley:
Thanks for all the advice though!
Golf IV 1.8T AUM
Golf V GT TDI PD170
