Author Topic: Ed35 more problems  (Read 9871 times)
Offline Ed35 chunk
Ed35 more problems
« on: 02 February 2013, 23:23 »
 :cry: was out in the ed35 today after being stored away last few weeks due to weather when a strange noise started at traffic lights I pulled straight over and on inspection noticed the cambelt hanging off and a cog hanging out on a angle! Quick call to vw assistance and car is now on driveway, maybe new engine our rebuild? I ave a feeling the next week is going to be fun  :smiley:
Gti ed35, dsg reflex silver met, rns510, dynaudio, rear cam, parking sensors, revo stage 2+, hpfp, revo intake, turbo back milltek non res inc sport cat,
Offline Murrayedition35
Re: Ed35 more problems
« Reply #1 on: 02 February 2013, 23:27 »
O dear..hope it's a quick fix... :shocked:
Offline Ed35 chunk
« Reply #2 on: 02 February 2013, 23:31 »
Engine runs but noisy the gog hanging out is at the bottom maybe water pump??
« Last Edit: 03 February 2013, 01:49 by Ed35 chunk »
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3 on: 03 February 2013, 10:44 »
The car runs so unlikely cam belt do you meen alternater belt?
Could be the clutch flywheel on the aircon?
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Hurdy
« Reply #4 on: 03 February 2013, 10:55 »
 :shocked:
If it is the cam belt and it is the bottom cog coming out then that is the cog that fits to the crankshaft!!!!!!!!
I'd expect that if this has moved then you'd be looking at a new engine under warranty as the cylinders will most likely have impacted with the valves and possibly have even broken rockers.
If it is the alternator belt I doubt if the engine would run noisy! And it only has pulleys, not cogs.
Seat Leon Cupra Black 290 DSG
Offline Ed35 chunk
« Reply #5 on: 03 February 2013, 11:32 »
Looks like the tensioner is hanging out on a angle, when rac guy started it up sounded bad, not what u expect on a 10 month old car with 4k
Offline Ed35 chunk
« Reply #6 on: 03 February 2013, 11:51 »
On closer inspection now in the light it's a bronze small ish cog hanging out midway dwn the driver side no where near bottom must not be crankshaft
Offline Hurdy
« Reply #7 on: 03 February 2013, 14:05 »
It would be a rare occurrence for the bottom cog to be out, however the tensioner being loose still isn't good as the timing belt can jump teeth which can be just as bad. My advice would be not to drive it and have it transported to the VW garage and ask for a full report.
« Last Edit: 03 February 2013, 14:21 by Hurdy »
Offline Neil gti
« Reply #8 on: 03 February 2013, 14:18 »
  :shocked: :sad: That's not good, feel for ya mate
Hope it gets sorted with minimal fuss and hope its not the timing belt that's slipped
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline Big_Dave
« Reply #9 on: 03 February 2013, 14:25 »
Good luck with all the issues the dealer may cause re: previous map :undecided:
Carbon Grey Edition 35, DSG, ACC, Cruise Control, Luxury Pack, RCD 510, TPMS
