Author Topic: Burning Smell!!!  (Read 1769 times)
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
Burning Smell!!!
« on: 30 January 2013, 21:34 »
Had an old friend who used to be a BMW mechanic over yesterday and we installed a stereo and flushed the coolant.
Together we narrowed down the burning smell to the exhaust directly under the drivers door/seat. He reckons it will be something burning on the hot exhaust but all we can see is some oil staining. I do lose some oil, so could there be a leak in this area? What would oil be doing faffing about that far back?
Thanks again guys, one day I might be able to help you!
I thought Volkswagens were supposed to be reliable?
Offline Dalo Harkin
Re: Burning Smell!!!
« Reply #1 on: 30 January 2013, 21:42 »
intercooler pipe, very common
behind drivers wheel, follow the pancake pipe back
Offline MoshiMoshi
« Reply #2 on: 31 January 2013, 00:26 »
Presumably the smell is crankcase oil vapours? Or oil leaking from the intercooler pipe and burning off?
What should i look out for on the pipes and what should i do?
Could this explain the 17705 drop in pressure between turbo and throttle body?
Offline Dalo Harkin
« Reply #3 on: 31 January 2013, 08:33 »
It'll be the oil burning on something, probably the exhaust
Oil, boost leaks leak oil, clean it off and then see if any of the pipes have popped off/jubilee clips loose
Yes
Offline MoshiMoshi
« Reply #4 on: 05 February 2013, 00:48 »
I've looked at the pipe, everything is fine.
However there is a fair amount of oil further up in the bowels of the engine. With the front right wheel at full lock I can see what appears to be the back of the block. It has oil on it and obviously a lot of road grime too. What on EARTH could be leaking down there?
Offline Dalo Harkin
« Reply #5 on: 05 February 2013, 07:15 »
could be anything, clear the grime away and then see if it re appears, a cleaner engine is easier to spot leaks on  :wink:
Offline GTi_James
« Reply #6 on: 05 February 2013, 17:17 »
and check your fuse box as well while your at it, mine started melting after changing electrics etc
