Author Topic: handbrake light still on after new sensor  (Read 2601 times)
Offline vwwvgolf
« on: 30 January 2013, 18:13 »
hello,
my handbrake light and abs light had been on since i brought the car. few months ago the bulb in the abs light blew.
finally got round to changing my drivers side rear abs sensor. i had tested it with the multimeter a while ago so knew it was that one. cleaned the abs rings up on both sides as they were covered in crap. went for a quick drive and handbrake light was off for a minute to start with but came back on. tried a quick skid to see if abs kicked in and it didnt.
is it possible that the abs bulb needs to be functioning so the handbrake light can go out? and for the abs to work again?
Offline Screech16v
  • MK3 20vt AGU
Re: handbrake light still on after new sensor
« Reply #1 on: 30 January 2013, 18:20 »
ABS ECU is most likely broken,but first check the fluid level and the handbrake switch to make sure,get the car scanned for fault codes
Offline vwwvgolf
« Reply #2 on: 30 January 2013, 18:22 »
yeah fluid levels and switch have been checked.
does the bulb have anything to do with it??
and yeah guna try and scan it after dinner
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 30 January 2013, 18:43 »
The bulb has nothing to do with abs fault .
Offline vwwvgolf
« Reply #4 on: 30 January 2013, 18:52 »
just scanned it and its showing both front sensors the rear right sensor (just changed) and also the abs pump
 :sad:
is there still chance its the abs ecu??   or would it show on the scan if its the ecu??
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 30 January 2013, 19:13 »
With that report of faults then I would put money on it, ive been there with mine !
Offline vwwvgolf
« Reply #6 on: 30 January 2013, 19:45 »
okay mate
thaaaaanks!!!
VW BUSH
« Reply #7 on: 30 January 2013, 19:46 »
Pay someone to fit and bleed the ABS pump if you need one as it can be a sh!t to do, the rest is easy although it can get expensive if its all fragged :wink:
I've had to change the lot too :grin:
Offline vwwvgolf
« Reply #8 on: 30 January 2013, 21:06 »
where exactly is the abs ecu?? ive searched google and here but cnt seem  to find it. only thing ive found is under rear seats but i know its not there
Offline Screech16v
  • MK3 20vt AGU
« Reply #9 on: 30 January 2013, 21:08 »
its bolted to the pump and has a big plug going to it.
