Author Topic: handbrake light still on after new sensor  (Read 2600 times)
Offline vwwvgolf
Re: handbrake light still on after new sensor
« Reply #10 on: 30 January 2013, 21:23 »
ha, fair enough, thanks for your help mate
Offline Screech16v
  • MK3 20vt AGU
« Reply #11 on: 30 January 2013, 21:31 »
No probs mate,it has four bolts holding it on think they are t5 and can be removed without breaking into the fluid system,send it off for testing ,tshirt2k off here did mine,pm him he may be able to help  :smiley:
Offline tshirt2k
  • Been there...Done that...
« Reply #12 on: 30 January 2013, 21:43 »
start in the engine bay
Mk3 ABF 16VT Megasquirt V3
Offline vwwvgolf
« Reply #13 on: 31 January 2013, 20:27 »
Offline vwwvgolf
« Reply #14 on: 01 February 2013, 10:51 »
im struggling a bit with removing the module. is there a guide on here how to do it or somewhere else??
Offline tshirt2k
« Reply #15 on: 02 February 2013, 10:01 »
Have you got an E5 socket? They can rust and lose shape. My original was like that and had to remove whole pump assembly to get the ecu off.
Offline vwwvgolf
« Reply #16 on: 02 February 2013, 15:57 »
no i havent got a e5 socket, i hadent even got that far haha. just frightn of braking stuff really.
however i did disconnect the harness left if for a bit and put it back in, scanned it and erased all the error codes for the abs ( 00283  / 00285   / 00287  / 00290  / 01276)  then re scanned it.
 it all came up with 00285.
 can anyone make anything of this?? should i  just try replacing the sensor, or should i just try to get the module out and try fix it??
Offline madmanmart
« Reply #17 on: 02 February 2013, 20:14 »
I have just bought another mk3 with the same faults,
Ordered a replacement pump and ECU and see how it goes.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline vwwvgolf
« Reply #18 on: 04 February 2013, 18:21 »
how much did that all cost and where from??
