Author Topic: Help with mould growth  (Read 2198 times)
Offline salsheikh
« on: 29 January 2013, 22:36 »
Guys, i need a bit of advice. I keep on getting mould growing behind the headboard and the picture frame and have to keep on cleaning it with mould killer regularly. It is on an external wall with no insulation due to the house being an early build.
Any suggestions on how I can stop this from happening?
« Last Edit: 29 January 2013, 22:47 by salsheikh »
Offline clipperjay
Re: Help with mould growth
« Reply #2 on: 29 January 2013, 23:17 »
WOW thats gonna hurt your familys lungs big time  :lipsrsealed:
Find the source then treat the symptoms!
But seriously get some detoi anti mold killer on it the spores will fu*ck you up!
Offline salsheikh
« Reply #3 on: 30 January 2013, 10:50 »
thanks for the advice  :cry:
Offline Len
« Reply #4 on: 30 January 2013, 10:59 »
Ventilation is the only cure.
More info required but at a pure guess is it an old house with solid wals and you have fitted PVC double glazing?
If so that is your problem.
www.sas.org.uk
www.the-ace.org.uk
Offline opel
« Reply #5 on: 30 January 2013, 17:44 »
Ventilation, heating, don't have your bed right up to the wall. We had it like mad ruined clothing and or wardrobe. We had to put extractor fans in kitchen and bathroom. Window vents in the windows.  It can be a range of things
Offline hobbiniho
« Reply #6 on: 30 January 2013, 18:54 »
yep ventilation is key iv seen so many houses where people block ventilators and then wonder why they are getting mould problems also try keeping the bed away from the walls so that the air can circulate, but your first priority is to get rid of the mould properly
this is the stuff that we use at work, you would need to treat the whole wall and not just the bit thats mouldy and repaint
http://www.sovchem.co.uk/condensation-control/mould-control-products/mould-control-pack.html
Offline Benrevs
« Reply #7 on: 30 January 2013, 21:43 »
Top pic looks cool... keep it!  :grin:
Offline golf-sib
  • Турботазик
« Reply #8 on: 30 January 2013, 23:15 »
Plant some button mushroom spores, at least you get some free food then... How old is the property, solid wall? I had similar problems, as said ventilation is key, I've installed two extractors running on humidity stats, one for bathroom, one for kitchen, started digging out the front garden as its filled with soil (over a foot from ground level) causing water retention and not allowing the walls to breath much. Once that's done, I'll add an additional down pipe (no down pipe currently) as well and maybe a third extractor to an additional room, but there has been huge improvements with every improvement done, joys of Victorian build!
Check for external wall for moss growth, moss helps hold moisture in, dettol kills moss quite well from experience, which I was suggested by a civil engineer friend, with black dots, I know chemicals containing copper they hate, otherwise top tip is usually use a bleach/chlorine solution to clean the area, but still try and fix the original problem otherwise you will get the mould returning. I know on fresh plaster its very rare to see mould due to the high levels of alkaline from the lime, which mould absolutely hates.
« Last Edit: 30 January 2013, 23:21 by golf-sib »
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline SI74
« Reply #9 on: 31 January 2013, 00:09 »
There's a reason this is happening. Your house must be letting in water some place and its making the wall damp. You need to find out where and stop it or this will get worse. No matter what you do if its not stopped where its getting in it will just keep coming back. You could be looking at a big bill to fix it but at the same time as said above this stuff can cause real health problems. My dad was a joiner for 45 years I'll show this to him and see what he says in the morning.
