Golf mk3
hardmonkeys
Broken by means of scraping
Topic: Broken by means of scraping (Read 2904 times)
joshstanvw
GTI forum regular
29 January 2013, 20:50 »
Please help guys I have lowered my golf and broken the bar that runs across the exhaust chamber near rear of the car and its dragging on the floor
so I'm guessing my question is do I need it or can I rip it off
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
ttelracs
The Fettler
Re: Broken by means of scraping
29 January 2013, 20:57 »
You can take it off as it is only held on by 4 x 17mm nuts. I removed mine to change the exhaust and simply never fitted it back, but will do as it does protect the exhaust over low speed humps etc.
Your choice ultimately...
joshstanvw
GTI forum regular
29 January 2013, 21:00 »
Thanks alot I will remove it as I have sheared all the bolts on one side
murraymint
29 January 2013, 21:15 »
I lot of people remove it. But il always leave it after my exhaust desided to split on the motorway. It split but just sat on this bar. Wouldn't like to think how it would of ended if I tok that off
josh
95 Mk3 golf 1.6 CL
96 Mk3 golf gti 16v
89 Mk2 Jetta GL
97 Mk3 golf gti 16v
99 bora 2ltr se
gazpowells
29 January 2013, 21:21 »
Yep remove it mate have done on mine
joshstanvw
GTI forum regular
29 January 2013, 21:24 »
It's gone used me scissor jack and wheel brace lol thanks guys big help that gives me a bit more clearance I broke it doin a 3 point turn and scraped middle of the road lol
Wayne
Sir Postalot
Reply #6 on:
29 January 2013, 21:27 »
Better to refit it if you can
murraymint
Reply #7 on:
29 January 2013, 21:30 »
Quote from: Wayne on 29 January 2013, 21:27
It's there for a reason after all
josh
95 Mk3 golf 1.6 CL
96 Mk3 golf gti 16v
89 Mk2 Jetta GL
97 Mk3 golf gti 16v
99 bora 2ltr se
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Reply #8 on:
29 January 2013, 21:34 »
yes, protects your exhaust.... and if it falls off and you won't loose it on the motorway when doing a hundred....
murraymint
Reply #9 on:
29 January 2013, 21:39 »
Exactly
josh
95 Mk3 golf 1.6 CL
96 Mk3 golf gti 16v
89 Mk2 Jetta GL
97 Mk3 golf gti 16v
99 bora 2ltr se
Golf mk3
hardmonkeys
