Author Topic: Spacer size required for R32 alloys on Mk5 GTI  (Read 3313 times)
Offline jb_4684
« on: 28 January 2013, 09:33 »
Hi folks,
I've just acquired some R32 alloys (the later style) to go on my Mk5 GTI, being a complete novice i thought they would be a straight swap, however, i've been told I need spacers?
The wheel reads- 225/40ZR18 92W XL and the alloys measure 19.5'' across.
Any idea what I will need to fit them and where I could get them from?
Kwik-fit, Halfords and VW have been unable to help so far!
Many Thanks
Jb
Re: Spacer size required for R32 alloys on Mk5 GTI
« Reply #1 on: 28 January 2013, 10:47 »
Thye should bolt straight on without spacers  :undecided:
Offline jb_4684
« Reply #2 on: 28 January 2013, 10:54 »
Exactly what I thought given that they are VW wheels! The guy said that without spacers there will be a lot of vibration when doing motorway miles.
Thank you for your reply.
« Reply #3 on: 28 January 2013, 10:56 »
Unless he means spiggot rings which locate the wheel onto the hub, are they genuine wheels.
Offline jb_4684
« Reply #4 on: 28 January 2013, 11:00 »
No he definitely said spacers and described them as a plastic part which sits in the gap between the plate and the screw holes on the alloy.
Yes they are genuine ones.
Thanks
Offline mcgee9t2
« Reply #5 on: 28 January 2013, 12:28 »
spacers should make no difference weather you get vibration on motorways.
spigot rings could cause the alloy wouldnt be touching the centre hub spiggot thingy (not sure what the sticky out bits called :D )
however i couldnt imagine the R having a different sized one to a GTI?
« Reply #6 on: 28 January 2013, 13:29 »
Thanks
If they are running plastic spiggot rings I suspect they are reps.
Offline jb_4684
« Reply #7 on: 28 January 2013, 14:11 »
Hi all, they are reps i've figured out although i was told they are gen. My bad- limited knowkedge around this area.
I am totally clueless now though, no one seems to know what size i need and i don't know how to work it out!
If anyone knows how to figure it out i'd be most grateful- there are so maby different types online.
Offline Gene Hunt.
« Reply #8 on: 01 February 2013, 05:25 »
If they were sold as being ''genuine'' then get you'r money back.
Candy White ED35.
Offline dTEA
  • back in an MK5
« Reply #9 on: 01 February 2013, 13:57 »
this. Genuine will be worth more...what did you pay an were they eBay?
Edition 30 / T5 T32 Kombi
