Author Topic: Pissin Me Ryt Off i wna ryt if off !!!!  (Read 2733 times)
Offline Itteh
  • Built Not Bought
« on: 27 January 2013, 18:24 »
Got the 8v fixed from the shudderin problem i had in past week, it was distributor cap and rotar, also changed igniton leads. now the cars been 100% for 2 days, and since the snow melted away, and its been raining i noticed a problem, the b**** turns off on me whilst im drivin it, n when it turns off it dunt start back up, i have to rev the fu** out of it, n it will start. but its a pain in the arse,  i dno what it is, also when i start it up in mornin at half 6 it is dark and when i turn lights on the car turns off, so could the whole problem be the battery? or something else ?
Offline spikenipple
Re: Pissin Me Ryt Off i wna ryt if off !!!!
« Reply #1 on: 27 January 2013, 18:27 »
Sounds like an earthing problem  :undecided:
Offline tweed
« Reply #2 on: 27 January 2013, 18:43 »
Sounds like earth to me also.
Has it been covered in snow?
Perhaps a leak somewhere and now the snow has melted, water has got in somewhere and shorting out.
Offline Itteh
  • Built Not Bought
« Reply #3 on: 27 January 2013, 19:38 »
Yep thats what some one said to me earthing but where could this bad earth be found ??? N yes it was covrred in snow not that bad tho but its windin me up , i fueled it up half tank n drove it sensibly for 2 days then it startin messin up n iv been givin it hell evrytym i get behnd the wheel
Offline _redders_
« Reply #4 on: 27 January 2013, 20:47 »
Told you !
Have you tried cleaning out the throttle body???
DROP IT LOW . . . ROLL IT SLOW
Offline Itteh
  • Built Not Bought
« Reply #5 on: 28 January 2013, 08:08 »
naa john i havent. its been fine this mornin' im deffo sure its only in the rain when it pisses about, this bad earth any idea hw to find the problem?
Offline arran.concept
  • Yellow Colour Concept
« Reply #6 on: 28 January 2013, 16:09 »
Check directly infront of your battery where your 3 main earths go down under the tray mate :). Had this issue last week.
Offline danmusic24
« Reply #7 on: 28 January 2013, 19:23 »
So you did not bother trying a different battery or new one then?
Told you in your in your old post,had the exact same issues....
It's got to worth a shot! Just to rule it out :wink:
Offline CJA321
« Reply #8 on: 28 January 2013, 22:42 »
Yup id atleast get the battery tested properly
Offline Itteh
  • Built Not Bought
« Reply #9 on: 29 January 2013, 09:06 »
its nt the battery, its been tested, thats perfect,
