Author Topic: Pissin Me Ryt Off i wna ryt if off !!!!  (Read 2736 times)
Offline Ninja
  • 19 smiles per gallon
Re: Pissin Me Ryt Off i wna ryt if off !!!!
« Reply #10 on: 30 January 2013, 20:05 »
its nt the battery, its been tested, thats perfect,
Ecu earth
Crank sensor
They should be your main focus points.
Had the exact same issue, it was the ecu earth.
Offline Martinvr6
« Reply #11 on: 30 January 2013, 20:28 »
I know I'm new around here but come on, stringing a sentence together without text talk can't be that hard can it?
Offline GOLF-MK3-GTI
« Reply #12 on: 30 January 2013, 20:41 »
It's crank shaft sensor, if your certain it's Cutting out in the wet, same problem I had on mine
Offline stow1985
  • 'when im cleaning winders'
« Reply #13 on: 30 January 2013, 21:36 »
Coil pack is starting to fail....soon it wont even spark, no spark no start
Worth checking the wires on the crank sensor first, if they look ok, not split or bare wires then go for coil, less agro changing the coil too
Good luck
