Author Topic: To much oil  (Read 3212 times)
Offline ShauniiBoii
To much oil
« on: 25 January 2013, 14:46 »
High there im new to the golf crowd so my question is would a high level of oil cause smoke to come out exhaust? iv noticed (not everytime i start) but say i leave it a couple days go to start ALOT of smoke comes from exhaust pretty much hides the car, i thought maybe engine / head gasket was wrecked, checked under oil cap and its clean as hell under there, checked oil level and it comes up to the 1st yellow bit thats on dip stick which is far to much!
so is engine a write off or is smoke due to amount of oil in it?
Thanks for any help guys :)
Offline barrym381
Re: To much oil
« Reply #1 on: 25 January 2013, 14:58 »
get the oil out of there really quick an dont drive it until you do an have put freash oil in to the right level,you might be lucky not to have done any damage  :smiley:
Offline ShauniiBoii
Re: To much oil
« Reply #2 on: 25 January 2013, 15:01 »
ok mate will do, car aint going anywhere wont move out of the drive way lol. so could it be the cause of smoke then? as i was thinking id have to buy a new engine etc and really wasn't looking forward to that after getting the car just last week
Offline barrym381
Re: To much oil
« Reply #3 on: 25 January 2013, 15:16 »
you might be lucky not to have damaged anythin,can only try  :smiley:
Offline ShauniiBoii
Re: To much oil
« Reply #4 on: 25 January 2013, 15:27 »
ok cool :) was only driven a couple days very short distance when i got it so fingers crossed cheers mate
Offline Dalo Harkin
Re: To much oil
« Reply #5 on: 26 January 2013, 08:21 »
over filling with oil will just damage the cat, the excess oil will sit there and that's why you get a huge cloud when starting
as said, remove what you can or drain it and add new to the level
Offline rockmonkey69
Re: To much oil
« Reply #6 on: 26 January 2013, 10:01 »
That much of an excess can destroy the engine, better get the oil level addressed.
Re: To much oil
« Reply #7 on: 26 January 2013, 13:50 »
Yous hould be able to drain some out via the dipstick tube.
Clear plastic tubing and a syringe will do the trick.
Offline barrym381
Re: To much oil
« Reply #8 on: 27 January 2013, 18:11 »
Is it really worth doing this when the oil prob needs changed anyway  :smiley:
Offline DubAndDubber
Re: To much oil
« Reply #9 on: 27 January 2013, 23:02 »
If the smoke is blue then it's goodbye turbo seals...
Mk5 Golf Gti 06'
