I think you're getting off topic a little here.
I like to be coherent and concise, you've clearly misconstrued this as a personal attack. I can't really apologise. It was not aimed at you, there was no reference to you and it is posted on a public forum. Not all members are as technically inclined and it helps to be coherent.
In the future avoid using someone else's thread to raise your concerns, that's what private messages are for.
Back on topic though, previous post with regards to increased oil pressure to the valve stem seal because of overfilled oil is incorrect, the oil is entering the combustion chamber because there is more oil on the bores than the piston oil scraper rings are able to handle. Let's get the oil level within correct levels first then go from there.
