Author Topic: Overheating problem  (Read 1993 times)
Offline BOGGLE
Overheating problem
« on: 24 July 2005, 16:48 »
Since i've had my 1.8t, there have been a couple of occasions when i have left it running to let the turbo cool and the forgotten about it.  It has then sat there and overheated.  I assumed it was the fan failing to work but when i took it to the garage the mechanic said that the fan was fine and this was a common problem with the mk4.  Well at Bugjam yesterday i left the car running as i had the stereo on and all of a sudden smoke appeared from under the bonnet and as before it had overheated just sitting there (trouble was i thought it was the BBQ next to my car at first)
Is this a common fault or is there something seriously wrong?
Before....During.....After
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: Overheating problem
« Reply #1 on: 24 July 2005, 17:19 »
Left mine running for almost an hour at BVF to use the stereo while we camped, and mine never overheated :undecided:
Offline fackie
« Reply #2 on: 24 July 2005, 17:46 »
Do you have Climatronic? Was it on? Can you hear it firing up very frequently? If yes to all, then it could be your A/C fan. Mine went bust like that and had to be replaced. Scared me sh!tless, but in the end that's all it was. Only happened when the vehicle was iddle; aparently if you're on the move it doesn't... Go figure...
Oh and btw, you WILL get a FREE iPOD if you follow these instructions:
http://www.freeiPods.com/?r=19715903
Offline BOGGLE
« Reply #3 on: 24 July 2005, 17:50 »
Yes i do have climatronic and yes to the rest of your questions.  Was this expensive to replace?
Offline fackie
« Reply #4 on: 24 July 2005, 17:55 »
argh... I feel for you... Just checked the invoice: it was about £310 for the repair, which included 2 fans being replaced. Aparently it was £80 just to find the fault...
Offline BOGGLE
« Reply #5 on: 24 July 2005, 17:58 »
I'm getting used to spending a sh!t load on this car tbh :sad:
Offline BOGGLE
« Reply #6 on: 24 July 2005, 17:59 »
fackie, what year is your car?
Offline fackie
« Reply #7 on: 24 July 2005, 18:03 »
It's a 2002 PD150, imported from Denmark, for the obvious reasons... Climatronic broke down at 2 years and 7 months, warranty only covered 2 years...
