Author Topic: Rear disc brakes stick  (Read 1729 times)
Offline churchygti
« on: 21 January 2013, 18:25 »
Hello,
My estate has rear discs brakes that i believe are from a gti. A friend told me that sticking rear disc brakes are common on the mk3 golf. He also mentioned that an upgrade to mk4 would stop this. If this is correct what needs to be done, or is there anything that makes them better i.e. dont stick with the mk3 ones i have.
Thanks people... Would be nice to use the handbrake  :smiley:
Estate Gti 16v
Offline leigh_harty
  • Audi AGU
Re: Rear disc brakes stick
« Reply #1 on: 21 January 2013, 18:30 »
Chances are they are getting moisture in and are frozen... and if this is the case the cable itself will eventually fail
Rear calipers of the mk4 is the way forward
Dont lose your dinosaur!
Offline churchygti
« Reply #2 on: 21 January 2013, 18:35 »
Thats what a friend mentioned whats the idea with the mark 4 and what will i need, is there a how to guide. Thanks
Estate Gti 16v
Offline tweed
« Reply #3 on: 21 January 2013, 18:44 »
It's just the caliper you need.
I think you will need to get brake lines too.
Offline tweed
« Reply #4 on: 21 January 2013, 18:48 »
I think Goodrich to the hose.
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 21 January 2013, 18:50 »
I have same problem. Main problem of the caliper seizing would be the seal on the piston is ripped and yo could purchase a rebuild kit from biggred under 30
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #6 on: 21 January 2013, 19:08 »
Defo move to mk4 calipers, have a look at this thread
http://www.golfgtiforum.co.uk/index.php?topic=247097.0
Offline boneybradley
  • Back in a Mk3...
« Reply #7 on: 21 January 2013, 19:40 »
I need to add. check the calipers because the mk3 handbrake cable also splits letting in moisture and it then freezes!
although I agree with mk4 calipers being better than the mk3 one's although they also have issues with seizures!! (goodridge do a hose kit for about £30 if you want to go mk4 although I would go for the full kit which is around £80)
I believe well maintained mk3 calipers work just as well myself (keep the handbrake mech clean and lubed and you shouldn't have issues)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #8 on: 21 January 2013, 20:40 »
Offline churchygti
« Reply #9 on: 21 January 2013, 21:01 »
thanks for your help. the mk4 upgrade looks like a good idea but i think ill have a good look incase a good clean will keep mine working better thanks all
Estate Gti 16v
