Author Topic: fitting TT bushes on wishbone Q  (Read 1972 times)
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
« on: 21 January 2013, 16:24 »
i am just in the middle of refurbing my old wishbones to refit to replace the cheap ebay ones i had to stick on. I am going with new front standard bushes and TT rear bushes my Q is fitting the bushes is that something i can do at home ? if so what would i need.
Thanks in advance
mike
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline dom
  • Back in a Mk4
Re: fitting TT bushes on wishbone Q
« Reply #1 on: 21 January 2013, 16:38 »
Thanks in advance
mike
Yeah, wishbone bushes are easy enough - you just need something to press them in with. I used a vice to do mine :wink:
Offline godsANGER
« Reply #2 on: 21 January 2013, 16:48 »
Thanks matei, that for both front and back?
Offline SI74
« Reply #3 on: 22 January 2013, 07:38 »
Yes. There's guides to should you how floating around.
Offline godsANGER
« Reply #4 on: 22 January 2013, 10:29 »
Nice one thanks matei  :cool:, best go hunting for the guides
Offline Prawny
  • R-tech power!!!
« Reply #5 on: 22 January 2013, 12:34 »
I did mine at the weekend using a vice, needs a fairly decent sized vice, but they will press in without the use of a hydraulic press.
Offline godsANGER
« Reply #6 on: 23 January 2013, 08:21 »
Thanks ill grab my mates work one should be big enough  :nerd:
Offline Prawny
  • R-tech power!!!
« Reply #7 on: 23 January 2013, 09:03 »
Make sure you clean up the face inside before pressing it in
Mine were like this before:
Cleaned up to this:
In the vice, use a steel plate so you press the bush evenly:
Go slowly, but it'll go:
Finished:
Sadly my poor vice wasn't really big enough:
Offline godsANGER
« Reply #8 on: 23 January 2013, 21:26 »
Cleaned up to this:
Finished:
thanks that s loads a help,
that last pic makes me feel sorry for the vice lol
Offline EsSeX dAn
« Reply #9 on: 24 January 2013, 15:29 »
if your fitting bushes with the sleeve ready installled, use a bit of thick wood with a hole that the skeeve will fit theough, otherwise you might ruin the bush. i used this method and a club hammer
i think i love you.....
