Author Topic: Frozen latch?  (Read 3975 times)
Offline John W
Frozen latch?
« on: 17 January 2013, 10:32 »
Well, my plan of using the Golf as a winter car has hit a snag. Each time I have been out to it first thing over the past few days, the drivers door won't open...... :sad:
It's a five door with remote locking (Through an alarm.) First day, every other door opened but not the drivers-the button didnt even pop up. I pulled it up (It was very stiff) from inside via the back door, but the door still wouldnt open with either inside or outside handle. A couple of hours later, it was fine and opened normally. (Once the temperature had risen a bit.)
Yesterday, the car wouldnt unlock at all-it would try but then relock, presumably because the drivers mechanism was again frozen. Again, a couple of hours later it was fine.
This morning, same again. Drivers door wouldn't open. Pulled the button up from inside with no effect, but this time left the car unlocked. An hour later the door opened normally.
Now this problem is clearly temperature/ice related as the locking has been 100% fine up until these cold temperatures. I have no idea what the internal lock/latch mechanism looks like, so where should I start in trying to sort this out ?
Many thanks.
Kind regards
John
1997 VW Golf GTI 8V 5 door
1979 Porsche 924 Lux
1982 Porsche 924 Lux Auto
1986 Porsche 944 Lux
1996 BMW 525iX SE Touring (4x4)
Offline javalin
Re: Frozen latch?
« Reply #1 on: 17 January 2013, 11:02 »
Same here - last two days have had to climb in the back.....
Two years ago I discovered that the drivers door lock inside the door got wet and then froze.  So with the door card off, covered it with lithum (I think) grease.  It was ok last year in -12c, but I guess its run off now and back to original problem.
Worth lube-ing the door seal too.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline arran.concept
  • Yellow Colour Concept
Re: Frozen latch?
« Reply #2 on: 17 January 2013, 11:19 »
Boiling hot water onto your key ?
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
Re: Frozen latch?
« Reply #3 on: 17 January 2013, 11:52 »
got the same problem with my 5door! might give the grease a go! rather annoying climbing over the passenger side haha
Mk4 Gti - Gone but not forgotten!
Offline GOLF-MK3-GTI
Re: Frozen latch?
« Reply #4 on: 17 January 2013, 12:07 »
Mine has been parked since last weekend, It was covered in snow, which then turned into ice.  :angry:
I poured hot water on all the door handles and unlocked doors via fob. Job done.
Offline javalin
Re: Frozen latch?
« Reply #5 on: 17 January 2013, 12:08 »
Offline itavaltalainen
Re: Frozen latch?
« Reply #6 on: 17 January 2013, 12:13 »
It's not the keyhole that is freezing but the actual lock assy.
If acute, plate you hand without glove under the key hole for a few minutes, this will sufficiently warm it up to open again.
For prevention, remove the black blanking plug on the side off the door and spray lithium grease there.
Or then take the lock out, clean, dry and regrease and you won't have the problem again for years.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: Frozen latch?
« Reply #7 on: 17 January 2013, 12:29 »
Just get a bottle of the Vw lock de over and it never freezes up once u have used this
I just put a bit in each winter
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline javalin
Re: Frozen latch?
« Reply #8 on: 17 January 2013, 12:34 »
>Vw lock de over
whats that then?  Their little "Lube" bottles you mean?
Offline dub_man_cabbie
Re: Frozen latch?
« Reply #9 on: 17 January 2013, 12:37 »
hiya sorry to go off thread but been trying to find u F17 BAD just finishing a 20v conversion in a mk3 and would love to pick ur brains about which intercooler u have used and if the pipework was a kit or have u made it up yourself. also which throttle cable did u use sorry again i cant find anywhere to pm you
cheers mate
