Author Topic: Frozen latch?  (Read 3977 times)
Offline tweed
Re: Frozen latch?
« Reply #10 on: 17 January 2013, 13:16 »
Wd40 spray in the locks at night?
I have a garage and it doesn't freeze at all  :grin: but I haven't started it for couple of weeks.
Offline kempie
  • where would we be without duct tape?
Re: Frozen latch?
« Reply #11 on: 17 January 2013, 13:27 »
i always defrost the windows with warm (not hot) water so with the bit left i run down the door seals and thats always done the trick for me :)
Offline leigh_harty
  • Audi AGU
Re: Frozen latch?
« Reply #12 on: 17 January 2013, 14:08 »
This is working for me... but wipe of the excess!
Pouring water over the handle.... that's just a daft idea (that, albeit works)
Dont lose your dinosaur!
Offline GOLF-MK3-GTI
Re: Frozen latch?
« Reply #13 on: 17 January 2013, 14:22 »
Lol, It may well be, But works for me  :grin:
Offline Screech16v
  • MK3 20vt AGU
Re: Frozen latch?
« Reply #14 on: 17 January 2013, 18:15 »
Same here ,tuesday morning took 30 mins to get in the drivers side  :grin:
Offline javalin
Re: Frozen latch?
« Reply #15 on: 17 January 2013, 18:23 »
oh well, snow for tomorrow but I have used coma spray grease in the holes mentioned.  We'll see if the doors open tomorrow.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline vwwvgolf
Re: Frozen latch?
« Reply #16 on: 17 January 2013, 18:26 »
It's not the keyhole that is freezing but the actual lock assy.
If acute, plate you hand without glove under the key hole for a few minutes, this will sufficiently warm it up to open again.
For prevention, remove the black blanking plug on the side off the door and spray lithium grease there.
Or then take the lock out, clean, dry and regrease and you won't have the problem again for years.
if this works you are a diamond!
its such a pain trying to get in the car at 7 in the morning freezing my nuttts off
Offline leigh_harty
  • Audi AGU
Re: Frozen latch?
« Reply #17 on: 17 January 2013, 18:47 »
and if i end up with a cold wet hand... and still locked out im gunna hunt you down  :grin:
Offline itavaltalainen
Re: Frozen latch?
« Reply #18 on: 17 January 2013, 20:09 »
quite confident it'll work ;)
done it a few times when i was still living in finland. and they have something that can actually be called winter....
current temps are autumn there.... i miss the snow ;)
Offline Ashy
Re: Frozen latch?
« Reply #19 on: 17 January 2013, 20:32 »
Same issues with the passenger door, looks like a job for weekend
