Author Topic: can you use 8v ignition leads on a 16v?  (Read 2295 times)
Offline whileoceanasleeps
  • patience comes to those who wait.
« on: 16 January 2013, 21:20 »
quick question if anyone knows.. as title! thanks
Offline tweed
Re: can you use 8v ignition leads on a 16v?
« Reply #1 on: 16 January 2013, 21:22 »
no
« Reply #2 on: 16 January 2013, 21:23 »
that was easy lol thanks
« Reply #3 on: 16 January 2013, 21:23 »
what about rotor arm?
« Reply #4 on: 16 January 2013, 21:25 »
Nope I am sure it is different as well  :undecided:
« Last Edit: 16 January 2013, 21:29 by Wayne »
Offline tweed
« Reply #5 on: 16 January 2013, 21:26 »
yes
Offline tweed
« Reply #6 on: 16 January 2013, 21:28 »
I thought the Bosch rotor fits both?
Offline DCmk3
« Reply #7 on: 16 January 2013, 22:15 »
I purchased a rotor for my 8v a couple of months back and the receipt said 16v rotor, not sure if it's the same or not though.
2014 Mk7 GTI - Littco L500
Offline joshstanvw
« Reply #8 on: 25 January 2013, 14:46 »
the 16v leads are different as on the 16v the plugs sit further into the block and on the 8v they protrude from the block you will find that the ones for the 16v are generally more expensive
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
« Reply #9 on: 26 January 2013, 18:29 »
I realised this today when I actually went to change the plugs. broke the end of one lead pulling it from the dizzy. soldered the end of an 8v lead on to the 16v one, result. so you can use 8v leads on a 16v  :evil:
