Author Topic: noise when down gearing  (Read 1170 times)
Offline NERF 69
« on: 16 January 2013, 12:08 »
Hi all i have a noise when down gearing i can also feel it through my gear stick. The only way i can describe it is it sounds like a dog barking can anyone give me any suggestions to what it could be? Other than Theres a dog in my gearbox lol.
Thank in advance
Sell my Vw??? I'd rather stick wasps up my arse
Offline asboGTI
Re: noise when down gearing
« Reply #1 on: 16 January 2013, 12:52 »
thats easy there a wolf in your gearbox :whistle:
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline tomparkes
  • OEM+
« Reply #2 on: 16 January 2013, 13:20 »
Haha, that could be a problem...
Not 100% sure mate, but I had a similar issue in an old Punto I used to drive (first car, piece of cr*p) and it turned out I was running dangerously low on gearbox oil - might be worth a check. I got it topped up and the noise/vibration disappeared.
2004 1.8T AUM | CM Silicone Hoses | Pipercross Panel Filter | Smoothed Stock Airbox | Weitec Ultra GT -40mm Springs & Shocks | Genuine 18" Anni BBS RC's | Anni GTI Front Grill Badge | Sharan Rear Badge | Polo Stubby Aerial | Black Centre Console
My Build Thread
Offline Dalo Harkin
« Reply #3 on: 16 January 2013, 13:55 »
oil as you have said or the synchros are on their way out  :angry:
Offline NERF 69
« Reply #4 on: 16 January 2013, 17:44 »
Can anyone tell how to check the oil level?
Offline rockmonkey69
« Reply #5 on: 16 January 2013, 17:56 »
There are two holes on the gearbox that are designated for filling and draining the gearbox oil, the one at the bottom is for draining and the one on the side is for filling. On a flat ground ,you fill up the gearbox until it starts to flow out of the hole on the side which your filling from, at which point you know the gearbox is filled to the correct level.
So you can remove the plug on the side and see if gearbox oil starts to leak from the side and top up as necessary. Our gearbox don't have a level dipstick.
Offline xxChrisxx
« Reply #6 on: 16 January 2013, 18:07 »
Thank in advance
The irony being it's the dog teeth that are marking the noise as the synchros are worn.
Or your clutch is worn/not adjusted and it's not fully disengaging.
If it's one gear - it's the synchro that's worn.
If it's all gears, your clutch needs adjusting.
Offline NERF 69
« Reply #7 on: 16 January 2013, 19:29 »
Thanks rockmonkey69 ill check that tomorrow.
Its happening in all gears. Ill look at oil levels first get the cheapest out the way then go from there. Ill post weather or not it solves the problem.
