Golf mk3
hardmonkeys
Outside temperature sensor
Topic: Outside temperature sensor (Read 1868 times)
squeakyduck
Just got here
13 January 2013, 18:21 »
Where is the outside temperature sensor located?
I noticed that on my 8v gti the temperature reads -25!! Would a new sensor cure this or do you think it could be another issue?
spikenipple
Re: Outside temperature sensor
13 January 2013, 18:32 »
It's on the off side bumper grille. Can't say I've seen that issue before!
murraymint
13 January 2013, 18:35 »
Mine was reading 18 last night
josh
95 Mk3 golf 1.6 CL
96 Mk3 golf gti 16v
89 Mk2 Jetta GL
97 Mk3 golf gti 16v
99 bora 2ltr se
squeakyduck
Just got here
19 January 2013, 14:40 »
Its all over the place at the moment. In the snow it changes from between -25 and +10!!
Does anyone have a part number from VW? I had a look online and the only thing I can see it thermostat sensors!!
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
19 January 2013, 14:47 »
Jumping from one temp to other might indicate that you got moisture in the plug....
Did you bump into a mountain of snow?
Would check that first, if you still want to replace it is 357919379A
Golf mk3
hardmonkeys
