Author Topic: What is this pipe?  (Read 3428 times)
Offline squeakyduck
What is this pipe?
« on: 13 January 2013, 18:18 »
Hey all,
I have been doing some repairs on my golf and I found this pipe that is leaking oil. Is it an oil breather line? It is the pipe that goes into a plastic box. It is located directly behind the dipstick and it leads up to the plastic box on the rocker cover.
Offline Khare
  • The bear that khares
Re: What is this pipe?
« Reply #1 on: 13 January 2013, 18:38 »
It is indeed the breather hose. It's very common for them to break, from the hot/cold cycles and age, the rubber they're made out of becomes brittle and easily cracks and snaps. There should be a horseshoe clip that holds it into the black box. Remove that, and you should see an O-ring. Give it all a good clean and replace the O-ring if needed.
Offline itavaltalainen
  • VCDS and VCP - fault codes, coding, VIM activation
« Reply #2 on: 13 January 2013, 22:10 »
also, i don't see a clip on the photo that should normally be there? is this below the pipe or just not there?
if not there, get a new o-ring and clip, that can help. only 100% solution is to get new pipe but vw want a fortune for a new one.
2019 Seat Leon ST FR DSG 135kW - eclipse orange - 23k miles
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 13 January 2013, 22:19 »
Thats the wrong pipe. That also looks like a rubber pipe. Correct1 is a hard plastic 1.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline spikenipple
« Reply #4 on: 13 January 2013, 22:32 »
If you need one of these breather pipes I have one here in good nick  :smiley:
Offline squeakyduck
« Reply #5 on: 19 January 2013, 14:43 »
Thanks for the info guys!
The pipe that is currently there is made from a soft plastic and it is crap to be honest. It is split into two pieces and jointed with a crappy plastic joiner.
I say i will buy this kit off ebay
http://www.ebay.co.uk/itm/Oil-Breather-Hose-Pipe-VW-GOLF-MK3-GTI-8V-037103211-037103493AE-037103213B-/111000903983?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19d82b612f
What do you think?
« Reply #6 on: 19 January 2013, 14:49 »
Main pipe (bendy long one) is the correct one, the second short one might not be.
But for 20£ get it..... you don't wanna know how much VW take for just that long one!
