Golf mk4
Wazzzer
starting problem
Topic: starting problem (Read 804 times)
mk4melv
starting problem
13 January 2013, 16:27 »
ive got a agu 1.8t golf and the other day it strugled to start every since its been a pain in the rear to start once running its ok but the throttle it a but unresponsive
any idaers gratly receved
thanks melv
sorry for the v poor spelling
asboGTI
Re: starting problem
13 January 2013, 19:18 »
Scanned it for codes
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
mk4melv
14 January 2013, 11:45 »
no havnt got a code scanner and cant find anyone local to do it for beer tokens
asboGTI
14 January 2013, 12:02 »
i would say i would scan in a couple of weeks but plans chjanged so wont be going devon
xxChrisxx
GTI forum regular
14 January 2013, 12:40 »
Old car? Cold weather?
The first thing to do is get a multimeter across the battery.
Dalo Harkin
14 January 2013, 12:44 »
then the next thing is a hand held code scanner from ebay for about £20, will definatley repay you in a few uses
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
tomparkes
OEM+
Reply #6 on:
14 January 2013, 12:51 »
I plan on getting Vag-Com in the not too distant future, but for now this is what I use and it works fine:
http://www.ebay.co.uk/itm/U281-VW-Audi-Skoda-Seat-VAG-CAN-BUS-Fault-Code-Reader-Scanner-diagnostic-tool-UK-/221040985066?pt=UK_Diagnostic_Tools_Equipment&hash=item337711c3ea
Dead easy to use, it'll give you any fault codes it finds (not 100% sure how reliable it is and whether it finds
everything
but it's better than nothing) and you can then search for these online to get a description (the manual only lists a handful of common codes) and possible actions to sort it. Once sorted/noted down, you can clear the codes from the car. This particular one apparently comes with a CD with all the fault codes listed on it, but I just use this to search for the codes as the explanations are decent - also search the forum here as there's likely already posts and solutions to anything you come across:
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
2004 1.8T AUM | CM Silicone Hoses | Pipercross Panel Filter | Smoothed Stock Airbox | Weitec Ultra GT -40mm Springs & Shocks | Genuine 18" Anni BBS RC's | Anni GTI Front Grill Badge | Sharan Rear Badge | Polo Stubby Aerial | Black Centre Console
My Build Thread
Golf mk4
Wazzzer
starting problem
