Author Topic: Apologies for sounding a bit dim... (Oil question)  (Read 2335 times)
Offline Big_Dave
« on: 13 January 2013, 12:04 »
The ed35 after 4000 miles needs a top up, it's just under half on the dipstick.
No problem, I'll look in the handbook for the specs...
After going through the handbook there is no suggestion (that I've found) of what it needs.
I'm guessing 5w 30 fully synthetic like castrol edge? Can anyone confirm this? Wanted it doing today before I need the car tomorrow.
Carbon Grey Edition 35, DSG, ACC, Cruise Control, Luxury Pack, RCD 510, TPMS
Offline candywhite12
Re: Apologies for sounding a bit dim... (Oil question)
« Reply #1 on: 13 January 2013, 12:07 »
mobil 5W40 fully synthetic, I believe the 5w30 is not fully compatible with vw engines, no?
Wife's: mk8 TSI 1.4 RL, 5dr atlantic blue, DSG, Norfolk 17", pan s/r, leds
Now: mk7.5 TSI 1.4 RL, 5dr tornado red, DSG, Singapore 17", pan s/r, leds
Before: mk6 GTI 5dr candy white, DSG, Monza Shadow 18", s/r, bi-Xenons, DCC
Even before that: mk5 GT 5dr tornado red, manual, s/r
Offline Big_Dave
« Reply #2 on: 13 January 2013, 12:48 »
Had a though...check castrol and Mobil 1 website!  :rolleyes:
5w30 they both reckon fully synthetic.
Cheers candywhite!
Offline Snooze
« Reply #3 on: 13 January 2013, 13:35 »
Yep 5w30 fully synthetic is what u need
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #4 on: 13 January 2013, 13:55 »
CAREFUL WITH MOBIL 1 ONLY ONE VERSION IS VW APPROVED.
In the manual it says the vw standard you need. Vw ###.##
Check the back of the can to make sure it is vw ###.## approved.
ONLY use oil APPROVED to this standard, DON'T use oil that says MEETS the standard either.
Meets meens nothing its a legal term it does not meen it has been tested.
Be very careful when trying to choose the correct oil.
Mine was billed to VW as using
Platinum 5 40
At its last two services at the main dealer
Quote
from the link i posted earlier
non-LongLife Time and Distance servicing for petrol engines is 502.00.  This is usually a fairly high spec 'fully synthetic' oil, SAE 5W40
Longlife oil
504.00 - is the spec for petrol engines, this is the latest VW LongLife "3" specification.  SAE 5W30.
Note about my photo of my oils
The Castrol edge is the longlife oil 5W30
The VW Quantum platinum is the non longlife oil 5W40
« Last Edit: 13 January 2013, 14:05 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
« Reply #5 on: 13 January 2013, 15:39 »
Platinum 5 40
Quote
Longlife oil
right on there, mobil 5W40 IS vw approved, 5w30 isn't, at least ones they are selling in Cyprus.  From what I see on the UK mobil site there's no 40 option, it's the 5w30 recommended for the 2.0 engine, Not sure about Castrol, I've been using the mobil one since always.
« Last Edit: 13 January 2013, 15:50 by candywhite12 »
Offline Big_Dave
« Reply #6 on: 13 January 2013, 17:47 »
Cheers for the advice guys...I've always used castrol so it's got castrol edge 5w30 in.
Offline Steve30
  • Ed30 .
« Reply #7 on: 14 January 2013, 14:45 »
I use that oil 5w30 ether quantum or Castrol longlife  :wink:
Tiguan quicker than the Golf
