Author Topic: what is the haldex??  (Read 1816 times)
Offline GTI.T
« on: 09 January 2013, 21:22 »
as the subject states and is it on all golfs?
Re: what is the haldex??
« Reply #1 on: 09 January 2013, 21:34 »
It is only fitted to the 4mo and R32 with 4wd
Offline dan2252
« Reply #2 on: 09 January 2013, 21:37 »
Basically it stops the rear wheels driving the car unless you boot it or it looses traction, and cost a fortune when they go wrong! Haha
MK4 golf 1.8 turbo agu :)
Offline GTI.T
« Reply #3 on: 09 January 2013, 21:38 »
Cheers wayne :)
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
« Reply #4 on: 10 January 2013, 22:09 »
Surely it's an electronically controlled differential? Am I right?
I thought Volkswagens were supposed to be reliable?
Offline sveed1.8T
« Reply #5 on: 11 January 2013, 09:59 »
Does that basically mean that it's not a full time 4wheel drive system, and more an elaborate form of traction control?!
Offline damien010685
« Reply #6 on: 11 January 2013, 10:06 »
Nope it's not perm 4x4 selective bases on loss of traction works well but as said can cost a lot when gone wrong
Offline Jin_C
« Reply #7 on: 11 January 2013, 10:30 »
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline sveed1.8T
« Reply #8 on: 11 January 2013, 10:48 »
Did audi use this system in their early quattros (mk1 TT, A3 Quattro etc). I don't get why you'd opt to have a system that would work part of the time but not all of the time? :undecided:
Did vw stick with this system with the Mk5, or did they opt for permanent 4X4?
Offline xxChrisxx
« Reply #9 on: 11 January 2013, 11:14 »
quattro is a permanent 'full fat' 4WD system. It's based on locking diffs (later torque sensing diffs).  Audi's used it becuase their engine configuration was/is longditudinally mounted.
You can't use this permanent system wth transverse mounted powertrain, so the Haldex system is used. Which uses a clutching system to mimic a centre diff. If you are running permanently like this the clutches burn out.
« Last Edit: 11 January 2013, 11:18 by xxChrisxx »
