Author Topic: Gear stick going straight across into reverse,  (Read 3377 times)
Offline beechymonza
  • mad beech
« on: 09 January 2013, 15:00 »
My gearstick on my gti will go straight across into reverse without me pushing it down,
Would this be the ball on the bottom of gearstick, \
Or is it the metal rod with the ball on it under engine bay,
I know thats a sh&t description but im not sure what its called,, :grin:
No guts No glory,
Offline Lewy
Re: Gear stick going straight across into reverse,
« Reply #1 on: 09 January 2013, 16:44 »
It'll be the plastic 'stop' that is worn. Lift up the gaiter and take a peek inside.
Offline beechymonza
  • mad beech
« Reply #2 on: 09 January 2013, 17:23 »
I have noticed that is worn down,
Can i purchase these,  :wink:
No guts No glory,
Offline weazgti
« Reply #3 on: 09 January 2013, 18:34 »
It is adjustable
Offline JC
  • Back in the North.
« Reply #5 on: 09 January 2013, 19:36 »
come and peek at mine  :lipsrsealed:
 :kiss:
Offline beechymonza
  • mad beech
« Reply #6 on: 09 January 2013, 20:14 »
Ok, So what does the ball on the side of the long bar do, Cause i might order 1 of those aswell
No guts No glory,
Offline prasina2
« Reply #7 on: 10 January 2013, 01:06 »
just be sure it's the lock out "plate" that's broken and not the finger on the shift lever. it will give the same symptom.
Happich latch replacement linkages for MK1/Mk2 pop-out windows, CNC aluminum...PM for details
Offline SoundillusioN
« Reply #8 on: 10 January 2013, 10:14 »
 :kiss:
Doesn't need peeking, just needs doing!  :drool:
Offline beechymonza
  • mad beech
« Reply #9 on: 10 January 2013, 11:59 »
Ok so i looked under the gear gaitor,  And the plastic stop has just come off in my hands, 1 of the corner pieces is broken off,
But on the gear shaft itself there is a piece that drops under the metal runner when going into reverse, This just goes straight under ,
No guts No glory,
