Author Topic: Gear stick going straight across into reverse,  (Read 3376 times)
Offline Steve_B
Re: Gear stick going straight across into reverse,
« Reply #10 on: 10 January 2013, 12:55 »
You need to replace the cup that the gearshaft sits in, will make it sit higher.
Offline beechymonza
  • mad beech
« Reply #11 on: 10 January 2013, 15:42 »
where is this cup,  Is this the ball thats underneath the car,,
No guts No glory,
Offline Steve_B
« Reply #12 on: 10 January 2013, 15:59 »
Yeah, look at gear linkage post in maintenance section for explanation of how to replace.
Offline beechymonza
  • mad beech
« Reply #13 on: 10 January 2013, 16:54 »
Ok, i already have this ball, Got it a few years ago, But not got around 2 doin it cause thought it was a big job,
So if i order that other clip part and maybe a new gearstick cause they not 2 dear either i should be sorted,,
No guts No glory,
Offline luke
  • When in doubt, whip it out!
« Reply #14 on: 12 January 2013, 22:55 »
Mine does this but I'm used to it so it never bothers me, just be gentle with the old girl
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
Offline weazgti
« Reply #15 on: 13 January 2013, 08:20 »
The ball and cup come together. Ball needs to be put in a vice and somehow removed which I didn't bother with on mine because the housing had a hole through it so I just changed that. It's 4 bolts underneath and there's holes in the exhaust heat shield to get a socket through.
