Golf mk4
Wazzzer
knocking
Topic: knocking (Read 1188 times)
mcgee9t2
knocking
08 January 2013, 14:26 »
Driving along then started hearing a loud knoking. sounded like the front O/S wheel was going to fall off. pulled over and cheked wheel nuts. all tight.
any ideas?
Going to jack the car up tonight and give the wheel a woble try see if its a bearing.
other things ive thought of was top mounts (how would i check to see if its them)
arb bushes ( has arb removed, i know. not the best idea i know. but its how the car was bought, didnt actualy notice no arb till i changed alloys. the cars too low to take corners fast atm anyway. will be getting raised and vrs arb put on in next few weeks)
wishbone bushes ( from a vishual inspection they all looked fine anyway to check)
cheers for any help.
wotavudunn
GTI forum regular
Re: knocking
08 January 2013, 14:49 »
you running spacers on the front? the bolt on type? they could be loose
mcgee9t2
Re: knocking
08 January 2013, 14:50 »
Nah no spacers. running coilovers. had the helper spring removed (coilovers getting changed to a different setup this weekend though)
mcgee9t2
Re: knocking
08 January 2013, 16:32 »
Ok drove home and knoking still there. when i push down on the wing you can sort of feel a clicking type thing and hear the knok so defanitly susp related ide say. gonna take the whel of and have a look in a few mins. have a feeling its top mounts. just a bit strange that its gone from fine to making a loud knoking noise in the matter of a few mins. hmm
any other ideas?
wotavudunn
GTI forum regular
Re: knocking
08 January 2013, 16:43 »
jack her up, take the wheel off, check all nuts and bolts are done up tightly. but tbh could be a number of things coilovers, top mount, wishbone bushes, track rod end or ball joint
mcgee9t2
Re: knocking
08 January 2013, 17:01 »
Just had a little look online see if i could find anything about seeing if topmounts are worn.
f
irst thing i found said jack car up and lift wheel if top mount rises then there worn. but i always thought there was ment to be some vertical play for when you turn? Can someone confirm this.
also someone said turn steering wheel with wheels on ground and i will see the top mounts move and creek?
Anyone know if these are ways to test? And if not anyone know a way?
cheers
JimBR
Re: knocking
Reply #6 on:
08 January 2013, 17:44 »
What coilovers are you running?
mcgee9t2
Re: knocking
Reply #7 on:
08 January 2013, 17:47 »
Fk
JimBR
Re: knocking
Reply #8 on:
08 January 2013, 18:03 »
Rock the strut forwards and backwards by hand and see if there's any play.
mcgee9t2
Re: knocking
Reply #9 on:
08 January 2013, 18:46 »
Yeah looks like its top mounts/top mount rubber bushes and bearings.
will be ok to drive aroun on till sat wownt it?
Sort of needs to be cause i have work and cant miss a day cause i have lots on that needs to be done.
Golf mk4
Wazzzer
knocking
