Author Topic: 8v gti won't start :@  (Read 4534 times)
Offline Graham.Concept
  • Yellow Colour Concept
Re: 8v gti won't start :@
« Reply #10 on: 07 January 2013, 19:26 »
Were is the fuel pump fuse or relay so I can check that also?
MK3 <3
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #11 on: 07 January 2013, 19:31 »
Its on the fuse box board behind cover just above the accelerator pedal.Its relay 167 bottom rhs of the fuse board.Try this http://www.golfgtiforum.co.uk/index.php?topic=74087.0
Rob
« Last Edit: 07 January 2013, 19:34 by dixie180 »
Offline tweed
« Reply #12 on: 07 January 2013, 19:48 »
I did the same to my 16v ran it dry, put a fall can in and it didn't start.
So my old man towed me down the road in his range rover bumping it. It fired and was fine untill I sold it.
« Last Edit: 08 January 2013, 10:18 by tweed »
« Reply #13 on: 07 January 2013, 20:04 »
Untill u sold it? Then what happened lol or do u have no idea? A will chek the dizzy and the fuses if no joy al try bumping but its been bumping fine whilst the battery has been f**ked, had to do it a few times
MK3 <3
Offline GOLF-MK3-GTI
« Reply #14 on: 07 January 2013, 20:38 »
It's happend to me before, where I've driven my car, and I've parked it up for a few hours, and once I've gone back to it, it's started and died out round the corner, so next day I bought a new coil and bingo, it works.
I have my doubts on coil, try that first
Offline tweed
« Reply #15 on: 07 January 2013, 20:45 »
It was fine for months. I sold it because I rubbed up a lorry and a lad on here put the abf in his mk2 that saw plenty of track days.
Offline Callum_K
« Reply #16 on: 07 January 2013, 21:26 »
Sorry didn't read your whole post, won't be the crank sensor obviously if you've already replaced it! Unless you bought a cheap one like I made the mistake of doing which failed within a week!
« Reply #17 on: 07 January 2013, 22:54 »
Well I got bored of sitting around waiting for the car to fix its self lol! Called on a fellow colour concept owner and set about it in the rain and dark haha, checked the plugs were sparking and yes no probs there! Checked fuel pump fuse- fine. Swapped the 167 relay with my mates car still no joy, tried jump leads again for another 10 mins no joy!! So was raging thru a wrope round it and the other golf n set about draggin it to car park!
Long story short, pull ing it in gear FINALY she coughed and spluttered then fired :D I am still anoyed that oit had to come to that but glad its nothing serious! Thanks to everyone tryna help me, appreciate n that's y I use this forum!
The CC safely at home :)
MK3 <3
« Reply #18 on: 08 January 2013, 10:08 »
if you were pulling it in gear and it started, it may well be your starter motor then
Offline tweed
« Reply #19 on: 08 January 2013, 10:18 »
Exactly what I said. And no it's not starter motor lol
