Author Topic: Setting the C0!  (Read 5965 times)
Offline Deefadog
  • Mk2 16V (November 89)
Setting the C0!
« on: 21 July 2005, 20:39 »
Ok, may sound like a stupid question  :embarassed:, but if i want my C0 set correctly to 2% (tried myself with no joy) is it just a case of taking it to a garage/MOT centre and they just put the exhaust analyser thing in the exhaust and set the mixture screw to get 2% showing up on the screen?
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
Re: Setting the C0!
« Reply #1 on: 21 July 2005, 21:50 »
yes. i took my 8valve to a vag 'specialist' only yesterday to sort out my thirsty, stalling noisy mk2! he was there for 1 and a half hours and he said that my mixture was something like 0.13 where a brand new car runs around the 0.15 mark!! he couldn't set the rest of the stuff as everything else has seized up!!! but, in answer to your question, that's all that is needed. :wink:
Offline Deefadog
Re: Setting the C0!
« Reply #2 on: 22 July 2005, 07:04 »
Cheers Dan,
I thought so  :rolleyes:
I'll get this set right first, before i start messing around to much!
I got the revs idleing now between 960 - 1020 (which is the recomended) but when fully warm she still sounds like she is hunting the engine still is not smooth! so i am hoping a C0 adjustment will sort this!
Offline Deefadog
Re: Setting the C0!
« Reply #3 on: 22 July 2005, 09:35 »
ok, got her booked into a friends place this afternoon!
now should the red lead be disconnected and the breather hole blocked? when setting the C0,or is it because he is using the emissions machine this is not needed?
Offline rowlers
  • I'm back - MK7 GTI
Re: Setting the C0!
« Reply #4 on: 22 July 2005, 13:25 »
Just done it!
purrs like a kitten now, took them about 20 mins!!!
Offline Deefadog
Re: Setting the C0!
« Reply #5 on: 22 July 2005, 13:37 »
Did they use the emissions machine? if so did they take the breather off and disconnect the red lead?
Offline rowlers
Re: Setting the C0!
« Reply #6 on: 22 July 2005, 18:18 »
yeh they used an emissions tester/analyser.
Couldn't tell you if they disconnected the breather and red lead or not - sorry!
Offline Deefadog
Re: Setting the C0!
« Reply #7 on: 22 July 2005, 18:30 »
No worries, got it done and they don't disconnect! :)
Anyway, do you know what they set your C0 to? mine was at 0.15 (very lean) but best was at around 0.80 and it runs very nice now!
But i have been told from the experts here that it should be set to 2.0% - i don't get this  :laugh:
Offline rowlers
Re: Setting the C0!
« Reply #8 on: 23 July 2005, 14:02 »
I asked the guy to set it at 2%, as advised by all the experts here.
So I assume that is what it is running at now - but can't be certain!!
Offline Deefadog
Re: Setting the C0!
« Reply #9 on: 23 July 2005, 14:05 »
I which i had one of those analyser machines! code really have a good play :)
