Golf mk3
hardmonkeys
ABS Pump
Topic: ABS Pump (Read 1873 times)
gazpowells
ABS Pump
03 January 2013, 13:24 »
I'm looking for a new abs pump
Does anyone if there is any difference between pump with part number
1h2 614 217 e and 1h2 614 217 c
As mine ends in C and have found one forsale ending E
Thanks in advance
Luke1981
Re: ABS Pump
03 January 2013, 13:58 »
I think the letter at the end which ends in E has superseded the C model and should fit ok.
I would phone your local VW garage and double check though.
MK IV GT TDI 150 PD / MKII CADDY SDI
gazpowells
Re: ABS Pump
03 January 2013, 15:56 »
Thanks mate
called VW very unhelpful and said they call me back
GOLF-MK3-GTI
Re: ABS Pump
03 January 2013, 16:21 »
Quote from: gazpowells on 03 January 2013, 15:56
Thanks mate
Majority of the VW Staff dont know their ass for their ear, I bet we'll know more than them
tshirt2k
Been there...Done that...
Re: ABS Pump
03 January 2013, 20:20 »
Are you sure you need a pump or is it the ecu?
Mk3 ABF 16V
T
Megasquirt V3
gazpowells
Re: ABS Pump
03 January 2013, 23:08 »
I have fault cosde 01276 so I'm guessing its abs pump
tshirt2k
Re: ABS Pump
Reply #6 on:
04 January 2013, 08:34 »
You may find that its an ecu fault. They are a common failure but can be repaired. Its the bit that's bolted underneath the pump. Would mean you wouldn't have to bleed your brakes too.
Mk3 ABF 16V
T
Megasquirt V3
gazpowells
Re: ABS Pump
Reply #7 on:
04 January 2013, 10:29 »
Thanks mate have done a search and found some info'
Can u remove the ecu without taking pump out then?
tshirt2k
Re: ABS Pump
Reply #8 on:
04 January 2013, 11:12 »
Yes. An E5 socket undoes the bolts.
Mk3 ABF 16V
T
Megasquirt V3
gazpowells
Re: ABS Pump
Reply #9 on:
04 January 2013, 20:48 »
Thanks mate will have a go tomorrow
Golf mk3
hardmonkeys
ABS Pump
