Author Topic: Von Religion Zu Kult  (Read 77339 times)
Offline jimmydub
Re: Von Religion Zu Kult
« Reply #90 on: 12 February 2013, 19:30 »
this project is amazing! you sir, are a visionary! black to white, brilliant. the vader lights! i'm gonna have to do mine like that now! the amp up above! mate...
how did you do the roof lining? need to do mine and would love some advise, even in broken english!
Offline Millhausen
« Reply #91 on: 13 February 2013, 10:12 »
They look nice and expensive no doubt but are they actually necessary on a mk3?
It's necessary to made upper camber to have safe clearence between S2 felgen and coilover ;)
It would be easier to use a smaller tyre or wheel spacers.
No, it wouldn't. His wheels are wide, so he needs the camber not only to get some arch clearance but also keep the inner of the rim away from the coil/adjuster rings.
How are £150 camber plates easier/cheaper than buying new tyres and or hubcentric spacers as well?
His way makes loads of sense, and I say that as I've been planning on doing it to mine for a while now.
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #92 on: 14 February 2013, 00:04 »
just read the whole thread... awesome man! you've put a lot of love into this!!
good photo skills too  :smiley:
Offline FraH2O
« Reply #93 on: 14 February 2013, 08:18 »
Are you using a translator program? Because its not very good. Pics look good tho. :afro:
No translator, sorry for bad langauge  :cry:. I'll try to improve...I upload many pics to try explain better than language.  :wink:
Thanks Mate....i'll show you with pics....better than explain.  :smiley:
To fix the amp, I used multi-hole tie, fixed on roof structs without mle any hole. The roof bracket just have holes to fix them
Yes mate, you explain well my trouble. Thanks!  :smiley:
thank you and to everybody for your comment and post. I'll try to make better by myself  :wink:
Offline FraH2O
« Reply #94 on: 14 February 2013, 08:52 »
Courtesy of Andrea Tasca (a photographer friend). :D
Offline jimmydub
« Reply #95 on: 14 February 2013, 11:42 »
hello again mate,
thanks for the info about the amp but i was actually wondering more about the roof lining itself. what was your process for wrapping it? what material did you use?
also i'm really interested how you did your headlights. why did you put them in the oven?! is the conversion to bi xenon easy?
new pics look great!
« Last Edit: 14 February 2013, 12:01 by jimmerehab »
« Reply #96 on: 14 February 2013, 12:19 »
hello again mate,
you put lights in the oven to soften the silicone so you can take off the glass and get inside :)
Offline jimmydub
« Reply #97 on: 14 February 2013, 12:24 »
i thought that was the case. i take it the rest of the unit has a higher temperature threshold?
Offline FraH2O
« Reply #98 on: 14 February 2013, 13:09 »
Open the glass from the rest of unit is also easy. You should put the oven with open door of oven (not close the oven's door!)
You must warm the headlight for 4 -5 minutes at 100 centigrades. Previous dismantle the 4 metal cips, you can open your glass pulling of the glass from the case (pay attention because the glass will be very hot)
I hope to explain the job...;)
Offline FraH2O
« Reply #99 on: 14 February 2013, 13:15 »
Fitting the xenon bulb is so easy (you should check only the height of the bulb to be sure that the bulb doesn't touch the glass when you'll close the headlight)
The bulb is fixxed on the chrome lens with a bracket screwed on the bulb, no need cut or modify the lens.
In the previous pages you can see my "rudimetal" fitting guide with pics.  :smiley:
