Author Topic: Von Religion Zu Kult  (Read 77381 times)
Offline FraH2O
Re: Von Religion Zu Kult
« Reply #70 on: 30 January 2013, 08:53 »
Time to refresh....
Some new necessary tools :D
And finally the sideskirt and the inside plstic wheel cover
10 - 15 days and the S2 will be ready for fitting.
Offline FraH2O
« Reply #71 on: 30 January 2013, 08:55 »
LA3A coming soon...
Offline FraH2O
« Reply #72 on: 30 January 2013, 08:56 »
Waiting the S2 and the new camber plates....i made my "mascott" to escort me to next treffen :D
And finally ready for final paint!
Offline FraH2O
« Reply #73 on: 30 January 2013, 08:59 »
Offline FraH2O
« Reply #74 on: 30 January 2013, 09:02 »
:D
Ready for close with the black screw. for me are very good result
Offline FraH2O
« Reply #75 on: 30 January 2013, 09:05 »
Finally i fitted the camber paltes (good machined from poland) They assure a -3° camber degree.
The fitting is so easy, but i found a trouble when i was fitting the second camber...
This spacer will make some trouble: the first is that lift the car, and the second is that i found 2 diffrernt wrong spacers for each camber
This is the trouble
There's a 1,3 cm of difference: th golf is higher on a side, but i check the problem when was time to screw the bolt on the damper thread :(
I solve the problem replacing the wrong apcers with these rebored bushes. They fitted perfectly wihout lifting the car.
The camber is made in 2 parts (upper and lower screwed with 8 bolts). I take the the lower to replace the rubber struts.
Loewering slow the car, and the camber will fit with any trouble.
Finish. Screw the 8 bolts. I place the camber with 90° degree from side spar. I make the right both camber with caliber.
These camber plate assure (with 0° degree at wheels) - 3° degree.
Offline FraH2O
« Reply #76 on: 30 January 2013, 09:08 »
Vader: "ffffffffffffuuuuuuuuuuuuu.....we can drop anymore..."..... :D
Offline FraH2O
« Reply #77 on: 30 January 2013, 09:10 »
Yesterday i finish finally the engine with this last detail
Like Predator blood....:P
And now the new canister FOx (it's the same for golf 3)
Offline FraH2O
« Reply #78 on: 30 January 2013, 09:12 »
And Sunday, with a good weather, I wash Hybrid02.
And this is a crazy gift of my best friends...:D
And now only the polyurethan seam and ready fr fit (maybe this friday)
Offline mark-mk3gti
« Reply #79 on: 30 January 2013, 23:10 »
love it! excellent work! very inspiring!  :smiley: :smiley: :smiley:
