Author Topic: Blocking off the evap canister pipe  (Read 4097 times)
Offline javalin
« on: 02 January 2013, 19:53 »
Hello,
What do people use to do this, i.e. the connector on the throttle body? Pictures?
I want to leave the valve in place and electrically connected to stop the ECU logging a fault code.
ta,
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Khare
  • The bear that khares
Re: Blocking off the evap canister pipe
« Reply #1 on: 02 January 2013, 20:00 »
I was actually about to post about this. Mine has been plugged in, but disconnected for a while now, and I want to get rid of it completely.
I hope you don't mind me hijacking this thread, but I too would like to know what's best to block the throttle body, and also what to use to block the pipe that runs from the fuel tank (I presume) to the canister.
Offline tweed
« Reply #2 on: 02 January 2013, 20:12 »
My doesn't have one, never looked how though  :grin:
Offline javalin
« Reply #3 on: 02 January 2013, 20:23 »
Hiya Khare, no I don't mind.  I had you in mind actually as I think I saw a thread recently where you said you'd done it.
Not fussed about the value->canister bits, just to stop the air intake into the throttle body.
Mine is obviously leaking somewhere as I got an code logged basically saying Lamdba at the limit of adaption - evap leak suggested on ross-tech.  Unplugging it solved it, just generates a new code saying open circuit for evap value....
James
Offline Khare
« Reply #4 on: 02 January 2013, 20:41 »
Mine has been unplugged for months and never throw up a code, how strange.
Tweed, go do me and Javalin a favour and tell us how yours is done  :smiley:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 02 January 2013, 22:22 »
I siliconed a small bolt into the throttle body vacuum outlet so that there were no air leaks,  i did the same for the one beside it that used to run to hot air valve on the airbox.
Disconnecting the purge valve and canister didn't bring up any running issues or fault codes on mine.
« Last Edit: 02 January 2013, 22:24 by thai-wronghorse »
Offline Khare
« Reply #6 on: 02 January 2013, 22:24 »
I plan to block both. I'll end up doing something along the lines of bolt and silicone probably.
I'm aiming for 170hp next month, need to get hold of a new airbox to work on.
Offline Ess_Three
« Reply #7 on: 03 January 2013, 09:39 »
I tapped the larger take-off (to Evap system) M8, and studlocked a M8 bolt in it, I removed the smaller take-off and tapped the TB casting M5 and studlocked an M5 bolt in there.
Nice and neat...and no leaks.
Quote
Same here.
..but gaining motorcycles.
« Reply #8 on: 03 January 2013, 09:58 »
Tapping them out properly is what will be done to mine when i finally get around to whipping off the intake manifold for refurbishment.
Offline Khare
« Reply #9 on: 03 January 2013, 10:55 »
Does the hose from the tank to the canister remain unblocked?
