Author Topic: Blocking off the evap canister pipe  (Read 4112 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Blocking off the evap canister pipe
« Reply #10 on: 03 January 2013, 11:04 »
Mine is just hanging down in the void where the canister used to be clipped to the plastic bracket.  I snapped the inlet off thecanister on removal so its still on the end of the hose albeit with a tiny bit of gauze over the end just to help stop too much crap going up inside it as its obviously pointing down near the road.
Offline Khare
  • The bear that khares
« Reply #11 on: 03 January 2013, 11:37 »
Cool, will find something to cover it to stop stuff going in (but fumes out).
Offline Len
« Reply #12 on: 03 January 2013, 13:31 »
Is there actually any benefit in doing this?
www.sas.org.uk
www.the-ace.org.uk
« Reply #13 on: 03 January 2013, 14:33 »
Yeah you ditch all the useless emissions crap from the bay which is well past its efficient best anyway.  You also have a quieter bay due to the loss of the annoying tapping that is created by the purge valve.  Some people have also commented  that their carbon  canisters also made unwanted noises.
Offline javalin
« Reply #14 on: 03 January 2013, 18:05 »
Out of interest this is the code I get - AGG engine with Simos ECU
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
            30-00 - Open or Short to Plus
This is the code I got leading to the removal of the evap value:
00537 - Lambda (Oxygen Sensor) Regulation
            19-10 - Lower Limit - Intermittent
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline javalin
« Reply #15 on: 06 January 2013, 13:20 »
This is how I did mine.  Not tested yet but should be fine.  Did the other end (to the canister) the same way, so the valve is completely disconnected pipe-wise.
http://javalins.wordpress.com/2013/01/06/evap-pipe-plug/
