Golf mk3
hardmonkeys
changing thermostat do i need to change the housing as well?
Topic: changing thermostat do i need to change the housing as well? (Read 1198 times)
Jasikasisback
01 January 2013, 23:42 »
just a quick question..do i need to change the housing as well or is this optional?
DCmk3
Here all the time
Re: changing thermostat do i need to change the housing as well?
01 January 2013, 23:44 »
The flange is a cheap part and they tend to break/warp over time so it's worth replacing at the same time.
2014 Mk7 GTI - Littco L500
thai-wronghorse
Serious forum addict
mk1 Seat Leon FR TDI
01 January 2013, 23:45 »
Its optional BUT be warned if its not been touched for years they are very prone to fracturing on removal or replacement.
Jasikasisback
01 January 2013, 23:50 »
ok will order from eurocarparts and have as a spare if needed!thanks as I will just get the order in before time is up!
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
02 January 2013, 16:22 »
just replace at the same time... not worth the hassle to redo everything... if the bolts look sh!te get 2 new ones as well. M6x22 and a thick washer if I remeber correctly.
Golf mk3
hardmonkeys
