Author Topic: which intake hose?  (Read 1940 times)
Offline davemk4
which intake hose?
« on: 30 December 2012, 12:18 »
am i right in thinking that this is a worth while upgrade
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=260301&product=FMGOLFIND
is there a cheaper option to get this upgraded part?
and this there any other hoses that give a performance upgrade like the one near the TB?  :smiley:
mk4 AUM by the way
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline stfc_gti
Re: which intake hose?
« Reply #1 on: 30 December 2012, 12:38 »
2002 1.8T GTI AUM, Standard (not for much longer)
Offline Nino
« Reply #2 on: 30 December 2012, 12:41 »
Hey bud they do help, i have been told the TIP like you posted increases air flow.
Anyway the cheapest i have found that are of good quality have been creation motor sports range, free shipping and feels well made, its what i have used, friendly and very helpful staff too.
I have got all fir my AUM apart from the TIP pipe which im yet to buy anyway the replace your pipes see links below.
http://www.creationsmotorsport.com/product-detail.php?pid=7
http://www.creationsmotorsport.com/product-detail.php?pid=56
http://www.creationsmotorsport.com/product-detail.php?pid=25
http://www.creationsmotorsport.com/product-detail.php?pid=17
Hope this helps :)
Current - MK6 GTi Edition 35
Offline davemk4
« Reply #3 on: 30 December 2012, 12:43 »
a lot of us run this one
http://www.ebay.co.uk/itm/VW-GOLF-MK4-1-8T-20V-SILICONE-TURBO-INTAKE-PIPE-AUM-AUQ-/160882537147
with no issues
thanks. im only changing it as i want to improve over the original. the forge one promotes it as bigger than oem and is proven to give better flow etc. wonder if the ebay one is bigger?
Offline Nino
« Reply #4 on: 30 December 2012, 13:12 »
The ebay one is the same as i posted, worth goving them an email and asking that? Also if u do get that, order it direct from there website as u wont have to pay posting fees :)
Offline davemk4
« Reply #5 on: 30 December 2012, 15:00 »
hmmmmmm so if i was to buy this
http://www.creationsmotorsport.com/product-detail.php?pid=65
this would replace the TB hose any way wouldnt it? then i could just get a intake pipe for the maf hose?
Offline Nino
« Reply #6 on: 30 December 2012, 17:04 »
personally I don't think thats worth getting, Im sure I have read somewhere that that makes little or no difference at all. stick to the ones I posted up make that way should one break its easyer to replae with your standard ones while you wait for your replacements (not that they do break)  :smiley:
Offline davemk4
« Reply #7 on: 30 December 2012, 18:30 »
cheers will do
Offline Rob Zombie
« Reply #8 on: 31 December 2012, 18:41 »
Ditto that dave said - I have the forge ones but tbh - the ones dave posted are pretty nice and real good bang for your buck!
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
Offline Big-G
« Reply #9 on: 31 December 2012, 23:46 »
If you can wait I think SFS are bringing out a larger 70mm version like the Badger5 large bore Tip (for the KO4) but to fit the AUM.
On a Remapped car it gained 10bhp over the stock tip. I expect it'll be a bit more pricey than those you've posted though  :rolleyes:
Gareth
My Build Thread (Ed38 sorry)
