Author Topic: Outside temp reading  (Read 1662 times)
Offline dannydubs
  • mk2 gti,mk3 wagon,mk5gti
« on: 28 December 2012, 17:22 »
My mk4 temp reading is showing on the clocks is very wrong
Shows temps outside like -20 and constantly changes and beeps but the outside temp on
The climate display panel is showing the correct Temp
I have changed the sensor in the front bumber with a genuine one from tps
but dash is still showing wrong temp
Is there another sensor any where
.....the project.........
Offline dannydubs
Re: Outside temp reading
« Reply #1 on: 02 January 2013, 00:17 »
Bump
Offline james2
  • No scammers please.
« Reply #2 on: 02 January 2013, 14:39 »
i think there one under the plastic panel were the front window wipers come out of. Im sure i saw one when i had to replace them.  :undecided:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline dannydubs
« Reply #3 on: 04 January 2013, 23:00 »
Is it for the ecu or dash clock tho
Offline mcgee9t2
« Reply #4 on: 05 January 2013, 00:59 »
pretty sure the one behind the bumper defanitly controls the temp for the clocks. not sure weather its a different one for the climatronic. but my old car didnt have the climatronic and still had the temp sensor behind the bumper for the temp on the clocks.
dodgey sensor ide say, unless theres another one somewere, but ive not heard of another sensor, and cant see why they would have two to do the same job?
Offline Tezmax
« Reply #5 on: 05 January 2013, 13:48 »
i have seen my temp reading on the dash +1/-1 against the climate control reading.
They could be two sensors based on the above :undecided:
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline dannydubs
« Reply #6 on: 09 January 2013, 18:31 »
Il try the other sensor aswell then
