Author Topic: condensation!  (Read 2848 times)
Offline tomparkes
  • OEM+
Re: condensation!
« Reply #10 on: 27 December 2012, 16:40 »
Also this arrived today, so I'm going to whack it in the boot overnight and it should eat up some of the moisture, which ought to help in the meantime - ideally I want to fix the leak and stop it altogether, but until it stops pi**ing down this will have to do.
http://www.ebay.co.uk/itm/DRY-AIR-CAR-HOME-DEHUMIDIFIER-BAG-MOISTURE-ABSORBER-DAMP-EATER-/221145155948?pt=UK_Car_Accessories_Car_Care_Cleaning&hash=item337d47496c
I also noticed there's three rubber grommets in the spare wheel well which may potentially perish, and with all the surface water around at the moment it could just as easily come up from under the car as well as from the sky - excellent! Good timing to buy a Mk4, eh??
2004 1.8T AUM | CM Silicone Hoses | Pipercross Panel Filter | Smoothed Stock Airbox | Weitec Ultra GT -40mm Springs & Shocks | Genuine 18" Anni BBS RC's | Anni GTI Front Grill Badge | Sharan Rear Badge | Polo Stubby Aerial | Black Centre Console
My Build Thread
Offline leigh_harty
  • Audi AGU
Re: condensation!
« Reply #11 on: 27 December 2012, 22:09 »
With it being winter you have to take into consideration your bringing moisture in with you... shoes etc
Nothing much but it may add to a problem
Dont lose your dinosaur!
Offline cooki
  • 1.8T AUM
Re: condensation!
« Reply #12 on: 28 December 2012, 12:49 »
Im having same problem. Ive just got a new pollen/cabin filter so fitting that tomoz.
Need to check all the usual places for water asap.
Another thing i was thinking of is ive recently fitted all brushed alu trim and a metal brushed alu gear knob so could thos be a factor in increased condensation coz its all metal now insyead of wood.
Had the same problem years ago when i fitted a roll cage to my corsa lol.
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
jockgti
Re: condensation!
« Reply #13 on: 01 January 2013, 12:21 »
did it work then?
Offline Dalo Harkin
Re: condensation!
« Reply #14 on: 02 January 2013, 13:03 »
Was it one that bolted through the panels? because that would be a more likely cause of moisture getting in
Offline harlemex
Re: condensation!
« Reply #15 on: 02 January 2013, 16:16 »
Absolutely.... No.  :grin:
Offline stace110
Re: condensation!
« Reply #16 on: 02 January 2013, 18:26 »
There's a grommet under the windscreen scuttle on the drivers side, in which the bonnet cable goes through ....Make sure that hasn't fallen out .Mine had and my windscreen was soaking wet...Ive resealed it and hey presto no more condensation.
1999 AGU, sitting on Dotz 18's,forge 008p, r32 side skirts. satin silver....more to come
