Author Topic: condensation!  (Read 2847 times)
Offline LittleM
  • Rust is not a crime
condensation!
« on: 26 December 2012, 17:20 »
New car- lots of condensation.
Scene from titanic quite possible !So why is this happening ...?
xxlittle m
Little M can get in a Golf
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: condensation!
« Reply #1 on: 26 December 2012, 17:59 »
Its a Mk4  :grin:
Chances are water is gettin in either via the door window regulator seals or the rain tray scuttle that covers the pollen filter is letting water in. Is any of your footwells damp inside?
Offline Haribo!
Re: condensation!
« Reply #2 on: 26 December 2012, 18:39 »
me and my brothers mk4's are both getting sh!t loads of condensation too. no wet carpets though. Can't find any trace of water inside :/
Both have had new windscreens in their time, I was wondering if we had just both been unlucky and had poorly fitted windscreens.
Offline asboGTI
Re: condensation!
« Reply #3 on: 27 December 2012, 08:10 »
try changing the pollen filters had something simlar before no water getting in but lots of condesation changed the pollen filter and it was fine after that
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Re: condensation!
« Reply #4 on: 27 December 2012, 09:37 »
Check the pollen filter housing as that tends to let water in also as suggested fit a new pollen filter as well.
Offline Rob Zombie
Re: condensation!
« Reply #5 on: 27 December 2012, 11:51 »
my bros mk4 suffered from this really bad - it's sure something that's very common on a lot of mk4's -hope mine doesnt start doing this too!
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
Offline stu646
Re: condensation!
« Reply #6 on: 27 December 2012, 11:59 »
I get it to, really annoying.
Some mornings I have to wait 10 minutes before setting off due to amount of condensation.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: condensation!
« Reply #7 on: 27 December 2012, 13:10 »
Same here with mine. It's due a new Pollen filter in April  which always seems to help for a bit. I might de humidify it with my parents portable unit soon and see if that cures it
Offline GTi_James
Re: condensation!
« Reply #8 on: 27 December 2012, 16:21 »
this +1, also if your using a dehumidifier make sure you have a safety heater as well, you'll be able to evaporate the moisture in the car and the dehumidifier then condenses the moisture so its not recirculated, also helps get rid of any hidden dampness and mold issues for under the carpet  :wink:
Offline tomparkes
  • OEM+
Re: condensation!
« Reply #9 on: 27 December 2012, 16:31 »
Have a look in the boot, under the carpet, in the spare wheel well. I've had my GTI for only a few weeks, and I've got the same problem with condensation. I've discovered that water is getting in through the boot somehow (I can see it trickling down the panel that clips into the body of the car at the back, directly beneath you when you lean in the boot) and it slowly fills up in the spare wheel well. If we ever get a dry day again (!) then I'm going to take all the trim out and try sealing the leak, provided I can find it.
I've read a load of threads both on here and on VW Vortex that suggest the rear cabin vents (located behind the trim panels and below the rear light clusters) are prone to leaking - the seals don't seem to have been particularly well made and it's a pretty common problem on the Mk4. You need to take the bumper off if you do discover it's these that are leaking and you can then seal around the edges of them with bathroom sealant - I think I'm right in saying that, but you might want somebody else to confirm.
I've got no problems in any of the footwells, so the water isn't getting in through the front of the vehicle, but I get a nice little paddling pool under my spare wheel. It'll be good on a hot day  :laugh:
2004 1.8T AUM | CM Silicone Hoses | Pipercross Panel Filter | Smoothed Stock Airbox | Weitec Ultra GT -40mm Springs & Shocks | Genuine 18" Anni BBS RC's | Anni GTI Front Grill Badge | Sharan Rear Badge | Polo Stubby Aerial | Black Centre Console
My Build Thread
